[Qgis-developer] Renaming Save Style -> Save Properties (Vector layer dialog)
Andreas Neumann a.neumann at carto.net
Sun Mar 2 03:39:16 PST 2014
How do you envisage to implement this?
Personally I would think it would be useful to have an export dialogue
where the user can choose (with checkboxes or a list widget) which
properties he wants to export:
* General properties (like the filtering, encoding, layer alias, scale
dependent visibility, CRS )
* Style properties
* Labeling properties
* Field properties (incl. display field properties)
* Actions
* Joins and Relations (see the new relations manager that Matthias
recently introduced)
* Diagrams
* Metadata
As a shortcut one should be able to export all at once without having to
press all checkboxes.
When importing, the importer of the layer properties should list what is
available in the .qml file and offer just the available bits of the
layer properties. Again - a short cut to import all layer properties
would be useful.
Thanks,
Andreas
Am 01.03.2014 15:42, schrieb Anita Graser:
> Hi Michael,
> Am 01.03.2014, 15:55 Uhr, schrieb kimaidou <kimaidou at gmail.com>:
>> I also think it could be great to have a button
>> "save style". But the latest should not lie in the bottom of the layer
>> dialog, but instead in the Style tab only, to avoid confusion.
> +1
>> By the way, having a "save style" button could also lead to the
>> ability of
>> saving/restoring more than one style for each layer (via a combo box for
>> the restore button), which could be great too.
> This could work quite well. Do you think the "Save style" button could
> be a simple button with the save icon or do we need a labeled button?
> Best wishes,
> Anita
>> Regards,
>> Michael
>> 2014-03-01 15:01 GMT+01:00 Régis Haubourg <
>> regis.haubourg at eau-adour-garonne.fr>:
>>> Hi Nathan I agree with your proposal of renaming style by properties.
>>> Users don't understand they also inherit labels, metadata and so on when
>>> loading a style.
>>> By the way, I think some improvements can be made for reloading style
>>> use
>>> case. Problem occurs (maybe occured, didn't check recently) when user
>>> want
>>> to transfer graduated or single value style classes from one column to
>>> another. Copying style from another table often leads to that situation,
>>> where field or expression is not in target table.   I know this can be
>>> tricky since graduated classes are in autosync with numeric data.
>>> Another issue occurs when geometry type is not the same. Maybe we could
>>> save
>>> at least color when reapplying style (from point to polygon for
>>> instance).
>>> This was my small thread highjack ;-)
>>> Cheers,
>>> Régis
