[Qgis-developer] Moving LizMap
rldhont rldhont at gmail.com
Tue Mar 4 02:25:12 PST 2014
Hi paolo,
LizMap is based on Jelix. http://docs.jelix.org/en/manual-1.4
In the temp/ directory of the application you can find a lizmap
directory. Doesn't remove it but remove all its content to have a clean
install.
The explaination is here :
http://docs.jelix.org/en/manual-1.4/create-application
   You have also a new directory temp/myapp, where all cached files
generated by Jelix will be stored.
Regards,
René-Luc D'Hont
3Liz
Le 04/03/2014 11:03, Paolo Cavallini a écrit :
> Hi all.
> Upon installation, LizMap compiles (in temp/) all its paths. When moving
> to a different virtualhost, the app is therefore no longer working. Of
> course I can change all the paths by hand, but this is boring and error
> prone. Is there a way of recompiling it automagically?
> Thanks.
