[Qgis-developer] Ideas to improve options of layer fields
Bernhard Ströbl
bernhard.stroebl at jena.de
Tue Mar 4 22:39:20 PST 2014
Am 04.03.2014 14:54, schrieb Rémi Bovard:
> Hi list,
> I'm currently implementing an edit form with a lot of fields and I've
> got some ideas to improve the user experience. What about to offer some
> new features in the layer fields options, like those ones:
if you are using a PostGIS db you can try my plugin DataDrivenInputMask
[1] which is in the repository
> - Set a default value (text, checkbox, date, list, etc.)
- works if default is defined on the field in the db
> - Set the order of the items in a values list
- if the values are derived from a second table with a fk constraint the
comboBox is "searchable", i.e. editable and positioned at the top of the
matching choices as you type
> - Set a field as mandatory and highlight it if empty (or even better,
> get constraint from the data provider)
if a not null constraint is defined on a field, changes cannot be
submitted if the field is still empty; null fields are indicated
Bernhard
> What do you think?
> Thank you for your feedback.
> Rémi
[1] https://github.com/bstroebl/DataDrivenInputMask/wiki
__________ Information from ESET Security, version of virus signature database 9501 (20140304) __________
The message was checked by ESET Security.
part000.txt - is OK
http://www.eset.com
