[Qgis-developer] qgis 2.2 crash
Enzo Cocca enzo.ccc at gmail.com
Thu Mar 6 08:04:31 PST 2014
hi all,
I have one problem with pyarchinit plugin and qgis 2.2 on win7. when I try
to make one action with this plugin qgis go in crash. I have an error that
win transform in a dump file.
I have debugged this file with wdk and below I put the debugging:
Microsoft (R) Windows Debugger Version 6.2.9200.20512 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File
[C:\Users\user\AppData\Local\Temp\qgis-20140306-094727-5224-6084-c3a2817.dmp]
User Mini Dump File: Only registers, stack and portions of memory are
available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path.           *
* Use .symfix to have the debugger choose a symbol path.                   *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
Windows 7 Version 7601 (Service Pack 1) MP (8 procs) Free x86 compatible
Product: WinNt, suite: SingleUserTS
Machine Name:
Debug session time: Thu Mar  6 09:47:28.000 2014 (UTC + 1:00)
System Uptime: not available
Process Uptime: 0 days 0:00:36.000
This dump file has an exception of interest stored in it.
The stored exception information can be accessed via .ecxr.
(1468.17c4): Access violation - code c0000005 (first/second chance not
available)
*** WARNING: Unable to verify timestamp for ntdll.dll
*** ERROR: Module load completed but symbols could not be loaded for
ntdll.dll
*** WARNING: Unable to verify timestamp for kernel32.dll
kernel32.dll
eax=00000000 ebx=0d980d78 ecx=0ee7a1d0 edx=00000265 esi=0d980d38
edi=0043b8cc
eip=77c30c32 esp=0043b58c ebp=0043b59c iopl=0         nv up ei pl zr na pe
nc
cs=0023  ss=002b  ds=002b  es=002b  fs=0053  gs=002b
efl=00000246
ntdll+0x20c32:
77c30c32 83c404          add     esp,4
0:000> The stored exception information can be accessed via .ecxr.
       ^ No runnable debuggees error in 'The stored exception information
can be accessed via .ecxr.'
0:000> (1468.17c4): Access violation - code c0000005 (first/second chance
not available)
       ^ Syntax error in '(1468.17c4): Access violation - code c0000005
(first/second chance not available)'
0:000> !analayze -v
No export analayze found
0:000> !analyze -v
*                        Exception Analysis
*** ERROR: Symbol file could not be found.  Defaulted to export symbols for
spatialiteprovider.dll -
core.pyd -
qgis_gui.dll -
***** OS symbols are WRONG. Please fix symbols to do analysis.
***** OS (WOW64 kernel32) symbols are WRONG. Please fix symbols to do
analysis.
***    Your debugger is not using the correct symbols                 ***
***    In order for this command to work properly, your symbol path   ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: nt!IMAGE_NT_HEADERS32                         ***
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by:                                    *
*   using the _NT_SYMBOL_PATH environment variable.                 *
*   using the -y <symbol_path> argument when starting the debugger. *
*   using .sympath and .sympath+                                    *
Unable to load image C:\Windows\SysWOW64\KERNELBASE.dll, Win32 error 0n2
*** WARNING: Unable to verify timestamp for KERNELBASE.dll
KERNELBASE.dll
ole32.dll -
user32.dll -
*** WARNING: Unable to verify timestamp for winmm.dll
winmm.dll
FAULTING_IP:
QtCore4!QString::operator==+8
67053478 8b4a08          mov     ecx,dword ptr [edx+8]
EXCEPTION_RECORD:  ffffffff -- (.exr 0xffffffffffffffff)
ExceptionAddress: 67053478 (QtCore4!QString::operator==+0x00000008)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 00000000
   Parameter[1]: 0000026d
Attempt to read from address 0000026d
DEFAULT_BUCKET_ID:  WRONG_SYMBOLS
PROCESS_NAME:  qgis-bin.exe
ADDITIONAL_DEBUG_TEXT:
You can run '.symfix; .reload' to try to fix the symbol path and load
symbols.
FAULTING_MODULE: 773c0000 kernel32
DEBUG_FLR_IMAGE_TIMESTAMP:  53052dad
MODULE_NAME: QtCore4
ERROR_CODE: (NTSTATUS) 0xc0000005 - L'istruzione a 0x%08lx ha fatto
riferimento alla memoria a 0x%08lx. La memoria non poteva essere %s.
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - L'istruzione a 0x%08lx ha fatto
EXCEPTION_PARAMETER1:  00000000
EXCEPTION_PARAMETER2:  0000026d
READ_ADDRESS:  0000026d
FOLLOWUP_IP:
APP:  qgis-bin.exe
PRIMARY_PROBLEM_CLASS:  WRONG_SYMBOLS
BUGCHECK_STR:  APPLICATION_FAULT_WRONG_SYMBOLS
LAST_CONTROL_TRANSFER:  from 6257b1dd to 67053478
STACK_TEXT:
WARNING: Stack unwind information not available. Following frames may be
wrong.
0043c688 6257b1dd 0043c968 972e5cba 4052e5cb QtCore4!QString::operator==+0x8
0043c784 6252ceeb 0043c968 972e5cba 4052e5cb
qgis_core!QgsSvgCache::svgAsImage+0x6d
0043c91c 6252d841 0e8d0358 0043c968 00000000
qgis_core!QgsSVGFillSymbolLayer::applyPattern+0x11b
0043c9b4 6253ddcc 00000001 0000ffff 00000000
qgis_core!QgsSVGFillSymbolLayer::applyDataDefinedSettings+0x4f1
0043c9e8 6252fc3d 0043caa4 9bbf786d 00000000
qgis_core!QgsFeatureRendererV2::_getPolygon+0x36c
0043ca80 624ffd70 0043cafc 00000000 0043caa4
qgis_core!QgsImageFillSymbolLayer::renderPolygon+0x6d
0043cac0 6253e593 0043cafc 00000000 05964f08
qgis_core!QgsFillSymbolV2::renderPolygon+0xa0
0043cb04 5d30a9f6 0043cb14 0043cb74 6276ec24
qgis_core!QgsFeatureRendererV2::renderFeatureWithSymbol+0x383
0043cb18 6255998d 6721175c 00000001 053948e0
spatialiteprovider!selectWidget+0x6586
0043cb7c 6269e3d9 053948e0 9bbf7d91 053948e0
qgis_core!QgsRuleBasedRendererV2::stopRender+0x10d
0043cc04 626aa880 0043ce04 053948e0 67055a00
qgis_core!QgsVectorLayer::drawRendererV2+0x289
0043cdfc 67055a00 0ec829a0 0c622068 0e8e60a0
qgis_core!QgsVectorLayer::draw+0x7b0
0043ce10 5cdd6f0b 3f800001 00000000 0043d018
QtCore4!QString::localeAwareCompare+0x250
0043ce20 5cdd6f1f 053948e0 0043d03c 0e8e60a0
core!OGREnvelope3D::Intersect+0x15f13b
0043d018 607bfbaa 0043d03c 00000000 9bbf61ae
core!OGREnvelope3D::Intersect+0x15f14f
0043d06c 6081e600 05329f70 0043d0ec 60888574
qgis_gui!QgsMapCanvasMap::render+0x10a
0043d080 607bb610 9bbf610e 0043d710 05329f70
qgis_gui!QgsMapCanvas::renderStarting+0x10
0043d0f4 607bf11c 9bbf6082 0043d710 05329f70
qgis_gui!QgsMapCanvas::refresh+0x1e0
00000000 00000000 00000000 00000000 00000000
qgis_gui!QgsMapCanvas::wheelEvent+0x17c
STACK_COMMAND:  ~0s; .ecxr ; kb
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  qtcore4!QString::operator==+8
FOLLOWUP_NAME:  MachineOwner
IMAGE_NAME:  QtCore4.dll
FAILURE_BUCKET_ID:  WRONG_SYMBOLS_c0000005_QtCore4.dll!QString::operator==
Followup: MachineOwner
0:000> lmvm spatialiteprovider.dll
start    end        module name
0:000> lmvm core.pyd
0:000> lmvm qgis_gui.dll
606d0000 609c6000   qgis_gui   (export symbols)       qgis_gui.dll
    Loaded symbol image file: qgis_gui.dll
    Mapped memory image file: C:\Program Files (x86)\QGIS
Valmiera\apps\qgis\bin\qgis_gui.dll
    Image path: C:\Program Files (x86)\QGIS
    Image name: qgis_gui.dll
    Timestamp:        Wed Feb 26 14:58:08 2014 (530DF2F0)
    CheckSum:         00300642
    ImageSize:        002F6000
    File version:     0.0.0.0
    Product version:  0.0.0.0
    File flags:       0 (Mask 0)
    File OS:          0 Unknown Base
    File type:        0.0 Unknown
    File date:        00000000.00000000
    Translations:     0000.04b0 0000.04e4 0409.04b0 0409.04e4
0:000> lmvm core
5cc20000 5d0d1000   core       (export symbols)       core.pyd
    Loaded symbol image file: core.pyd
Valmiera\apps\qgis\python\qgis\core.pyd
    Image name: core.pyd
    Timestamp:        Wed Feb 26 14:56:22 2014 (530DF286)
    CheckSum:         004AC88F
    ImageSize:        004B1000
5d2f0000 5d335000   spatialiteprovider   (export symbols)
    Loaded symbol image file: spatialiteprovider.dll
Valmiera\apps\qgis\plugins\spatialiteprovider.dll
    Image name: spatialiteprovider.dll
    Timestamp:        Wed Feb 26 14:59:06 2014 (530DF32A)
    CheckSum:         000471D6
    ImageSize:        00045000
any idea???
thanks
Enzo Cocca (PhD Candidate)
Research Fellow
Università di Napoli "L'Orientale"
mail: enzo.ccc at gmail.com
cell: +393495087014
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140306/1dcec210/attachment-0001.html>
