[Qgis-developer] [solved] qgis 2.2 crash
Enzo Cocca enzo.ccc at gmail.com
Fri Mar 7 08:13:29 PST 2014
The problem of crash was the simbology of qgis 1.8 that I have used to qgis
2.2.
thanks!
2014-03-06 17:04 GMT+01:00 Enzo Cocca <enzo.ccc at gmail.com>:
> hi all,
> I have one problem with pyarchinit plugin and qgis 2.2 on win7. when I try
> to make one action with this plugin qgis go in crash. I have an error that
> win transform in a dump file.
> I have debugged this file with wdk and below I put the debugging:
> Microsoft (R) Windows Debugger Version 6.2.9200.20512 AMD64
> Copyright (c) Microsoft Corporation. All rights reserved.
> Loading Dump File
> [C:\Users\user\AppData\Local\Temp\qgis-20140306-094727-5224-6084-c3a2817.dmp]
> User Mini Dump File: Only registers, stack and portions of memory are
> available
> Symbol search path is: *** Invalid ***
> * Symbol loading may be unreliable without a symbol search path.
> * Use .symfix to have the debugger choose a symbol path.
> * After setting your symbol path, use .reload to refresh symbol locations.
> Executable search path is:
> Windows 7 Version 7601 (Service Pack 1) MP (8 procs) Free x86 compatible
> Product: WinNt, suite: SingleUserTS
> Machine Name:
> Debug session time: Thu Mar  6 09:47:28.000 2014 (UTC + 1:00)
> System Uptime: not available
> Process Uptime: 0 days 0:00:36.000
> This dump file has an exception of interest stored in it.
> The stored exception information can be accessed via .ecxr.
> (1468.17c4): Access violation - code c0000005 (first/second chance not
> available)
> *** WARNING: Unable to verify timestamp for ntdll.dll
> *** ERROR: Module load completed but symbols could not be loaded for
> ntdll.dll
> *** WARNING: Unable to verify timestamp for kernel32.dll
> kernel32.dll
> eax=00000000 ebx=0d980d78 ecx=0ee7a1d0 edx=00000265 esi=0d980d38
> edi=0043b8cc
> eip=77c30c32 esp=0043b58c ebp=0043b59c iopl=0         nv up ei pl zr na pe
> nc
> cs=0023  ss=002b  ds=002b  es=002b  fs=0053  gs=002b
> efl=00000246
> ntdll+0x20c32:
> 77c30c32 83c404          add     esp,4
> 0:000> The stored exception information can be accessed via .ecxr.
>        ^ No runnable debuggees error in 'The stored exception information
> can be accessed via .ecxr.'
> 0:000> (1468.17c4): Access violation - code c0000005 (first/second chance
> not available)
>        ^ Syntax error in '(1468.17c4): Access violation - code c0000005
> (first/second chance not available)'
> 0:000> !analayze -v
> No export analayze found
> 0:000> !analyze -v
> *                        Exception Analysis
> *** ERROR: Symbol file could not be found.  Defaulted to export symbols
> for spatialiteprovider.dll -
> for core.pyd -
> for qgis_gui.dll -
> ***** OS symbols are WRONG. Please fix symbols to do analysis.
> ***** OS (WOW64 kernel32) symbols are WRONG. Please fix symbols to do
> analysis.
> ***    Your debugger is not using the correct symbols                 ***
> ***    In order for this command to work properly, your symbol path   ***
> ***    must point to .pdb files that have full type information.      ***
> ***    Certain .pdb files (such as the public OS symbols) do not      ***
> ***    contain the required information.  Contact the group that      ***
> ***    provided you with these symbols if you need this command to    ***
> ***    work.                                                          ***
> ***    Type referenced: nt!IMAGE_NT_HEADERS32                         ***
> * Symbols can not be loaded because symbol path is not initialized. *
> * The Symbol Path can be set by:                                    *
> *   using the _NT_SYMBOL_PATH environment variable.                 *
> *   using the -y <symbol_path> argument when starting the debugger. *
> *   using .sympath and .sympath+                                    *
> Unable to load image C:\Windows\SysWOW64\KERNELBASE.dll, Win32 error 0n2
> *** WARNING: Unable to verify timestamp for KERNELBASE.dll
> KERNELBASE.dll
> for ole32.dll -
> for user32.dll -
> *** WARNING: Unable to verify timestamp for winmm.dll
> winmm.dll
> FAULTING_IP:
> QtCore4!QString::operator==+8
> 67053478 8b4a08          mov     ecx,dword ptr [edx+8]
> EXCEPTION_RECORD:  ffffffff -- (.exr 0xffffffffffffffff)
> ExceptionAddress: 67053478 (QtCore4!QString::operator==+0x00000008)
>    ExceptionCode: c0000005 (Access violation)
>   ExceptionFlags: 00000000
> NumberParameters: 2
>    Parameter[0]: 00000000
>    Parameter[1]: 0000026d
> Attempt to read from address 0000026d
> DEFAULT_BUCKET_ID:  WRONG_SYMBOLS
> PROCESS_NAME:  qgis-bin.exe
> ADDITIONAL_DEBUG_TEXT:
> You can run '.symfix; .reload' to try to fix the symbol path and load
> symbols.
> FAULTING_MODULE: 773c0000 kernel32
> DEBUG_FLR_IMAGE_TIMESTAMP:  53052dad
> MODULE_NAME: QtCore4
> ERROR_CODE: (NTSTATUS) 0xc0000005 - L'istruzione a 0x%08lx ha fatto
> riferimento alla memoria a 0x%08lx. La memoria non poteva essere %s.
> EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - L'istruzione a 0x%08lx ha fatto
> EXCEPTION_PARAMETER1:  00000000
> EXCEPTION_PARAMETER2:  0000026d
> READ_ADDRESS:  0000026d
> FOLLOWUP_IP:
> APP:  qgis-bin.exe
> PRIMARY_PROBLEM_CLASS:  WRONG_SYMBOLS
> BUGCHECK_STR:  APPLICATION_FAULT_WRONG_SYMBOLS
> LAST_CONTROL_TRANSFER:  from 6257b1dd to 67053478
> STACK_TEXT:
> WARNING: Stack unwind information not available. Following frames may be
> wrong.
> 0043c688 6257b1dd 0043c968 972e5cba 4052e5cb
> QtCore4!QString::operator==+0x8
> 0043c784 6252ceeb 0043c968 972e5cba 4052e5cb
> qgis_core!QgsSvgCache::svgAsImage+0x6d
> 0043c91c 6252d841 0e8d0358 0043c968 00000000
> qgis_core!QgsSVGFillSymbolLayer::applyPattern+0x11b
> 0043c9b4 6253ddcc 00000001 0000ffff 00000000
> qgis_core!QgsSVGFillSymbolLayer::applyDataDefinedSettings+0x4f1
> 0043c9e8 6252fc3d 0043caa4 9bbf786d 00000000
> qgis_core!QgsFeatureRendererV2::_getPolygon+0x36c
> 0043ca80 624ffd70 0043cafc 00000000 0043caa4
> qgis_core!QgsImageFillSymbolLayer::renderPolygon+0x6d
> 0043cac0 6253e593 0043cafc 00000000 05964f08
> qgis_core!QgsFillSymbolV2::renderPolygon+0xa0
> 0043cb04 5d30a9f6 0043cb14 0043cb74 6276ec24
> qgis_core!QgsFeatureRendererV2::renderFeatureWithSymbol+0x383
> 0043cb18 6255998d 6721175c 00000001 053948e0
> spatialiteprovider!selectWidget+0x6586
> 0043cb7c 6269e3d9 053948e0 9bbf7d91 053948e0
> qgis_core!QgsRuleBasedRendererV2::stopRender+0x10d
> 0043cc04 626aa880 0043ce04 053948e0 67055a00
> qgis_core!QgsVectorLayer::drawRendererV2+0x289
> 0043cdfc 67055a00 0ec829a0 0c622068 0e8e60a0
> qgis_core!QgsVectorLayer::draw+0x7b0
> 0043ce10 5cdd6f0b 3f800001 00000000 0043d018
> QtCore4!QString::localeAwareCompare+0x250
> 0043ce20 5cdd6f1f 053948e0 0043d03c 0e8e60a0
> core!OGREnvelope3D::Intersect+0x15f13b
> 0043d018 607bfbaa 0043d03c 00000000 9bbf61ae
> core!OGREnvelope3D::Intersect+0x15f14f
> 0043d06c 6081e600 05329f70 0043d0ec 60888574
> qgis_gui!QgsMapCanvasMap::render+0x10a
> 0043d080 607bb610 9bbf610e 0043d710 05329f70
> qgis_gui!QgsMapCanvas::renderStarting+0x10
> 0043d0f4 607bf11c 9bbf6082 0043d710 05329f70
> qgis_gui!QgsMapCanvas::refresh+0x1e0
> 00000000 00000000 00000000 00000000 00000000
> qgis_gui!QgsMapCanvas::wheelEvent+0x17c
> STACK_COMMAND:  ~0s; .ecxr ; kb
> SYMBOL_STACK_INDEX:  0
> SYMBOL_NAME:  qtcore4!QString::operator==+8
> FOLLOWUP_NAME:  MachineOwner
> IMAGE_NAME:  QtCore4.dll
> FAILURE_BUCKET_ID:  WRONG_SYMBOLS_c0000005_QtCore4.dll!QString::operator==
> Followup: MachineOwner
> 0:000> lmvm spatialiteprovider.dll
> start    end        module name
> 0:000> lmvm core.pyd
> 0:000> lmvm qgis_gui.dll
> 606d0000 609c6000   qgis_gui   (export symbols)       qgis_gui.dll
>     Loaded symbol image file: qgis_gui.dll
>     Mapped memory image file: C:\Program Files (x86)\QGIS
> Valmiera\apps\qgis\bin\qgis_gui.dll
>     Image path: C:\Program Files (x86)\QGIS
>     Image name: qgis_gui.dll
>     Timestamp:        Wed Feb 26 14:58:08 2014 (530DF2F0)
>     CheckSum:         00300642
>     ImageSize:        002F6000
>     File version:     0.0.0.0
>     Product version:  0.0.0.0
>     File flags:       0 (Mask 0)
>     File OS:          0 Unknown Base
>     File type:        0.0 Unknown
>     File date:        00000000.00000000
>     Translations:     0000.04b0 0000.04e4 0409.04b0 0409.04e4
> 0:000> lmvm core
> 5cc20000 5d0d1000   core       (export symbols)       core.pyd
>     Loaded symbol image file: core.pyd
> Valmiera\apps\qgis\python\qgis\core.pyd
>     Image name: core.pyd
>     Timestamp:        Wed Feb 26 14:56:22 2014 (530DF286)
>     CheckSum:         004AC88F
>     ImageSize:        004B1000
> 5d2f0000 5d335000   spatialiteprovider   (export symbols)
>     Loaded symbol image file: spatialiteprovider.dll
> Valmiera\apps\qgis\plugins\spatialiteprovider.dll
>     Image name: spatialiteprovider.dll
>     Timestamp:        Wed Feb 26 14:59:06 2014 (530DF32A)
>     CheckSum:         000471D6
>     ImageSize:        00045000
> any idea???
> thanks
> Enzo Cocca (PhD Candidate)
> Research Fellow
> Università di Napoli "L'Orientale"
> mail: enzo.ccc at gmail.com
> cell: +393495087014
Research Fellow
cell: +393495087014
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140307/e6395f02/attachment-0001.html>
