[Qgis-developer] [solved] qgis 2.2 crash
Enzo Cocca enzo.ccc at gmail.com
Fri Mar 7 08:35:24 PST 2014
Unfortunatly It happen. I used a not complex simbolgy to fill polygon but I
noticed that the colors are very different from qgis style 1.8 to qgis
style 2.2. The problem is in color paletts?
enzo
2014-03-07 17:26 GMT+01:00 G. Allegri <giohappy at gmail.com>:
> That's a really bad story. I don' excpet to have complete back
> compatibility, but a crash shouldn't happen :(
> giovanni
> 2014-03-07 17:13 GMT+01:00 Enzo Cocca <enzo.ccc at gmail.com>:
>> The problem of crash was the simbology of qgis 1.8 that I have used to
>> qgis 2.2.
>> thanks!
>> 2014-03-06 17:04 GMT+01:00 Enzo Cocca <enzo.ccc at gmail.com>:
>>> hi all,
>>> I have one problem with pyarchinit plugin and qgis 2.2 on win7. when I
>>> try to make one action with this plugin qgis go in crash. I have an error
>>> that win transform in a dump file.
>>> I have debugged this file with wdk and below I put the debugging:
>>> Microsoft (R) Windows Debugger Version 6.2.9200.20512 AMD64
>>> Copyright (c) Microsoft Corporation. All rights reserved.
>>> Loading Dump File
>>> [C:\Users\user\AppData\Local\Temp\qgis-20140306-094727-5224-6084-c3a2817.dmp]
>>> User Mini Dump File: Only registers, stack and portions of memory are
>>> available
>>> Symbol search path is: *** Invalid ***
>>> * Symbol loading may be unreliable without a symbol search path.
>>> * Use .symfix to have the debugger choose a symbol path.
>>> * After setting your symbol path, use .reload to refresh symbol
>>> locations. *
>>> Executable search path is:
>>> Windows 7 Version 7601 (Service Pack 1) MP (8 procs) Free x86 compatible
>>> Product: WinNt, suite: SingleUserTS
>>> Machine Name:
>>> Debug session time: Thu Mar  6 09:47:28.000 2014 (UTC + 1:00)
>>> System Uptime: not available
>>> Process Uptime: 0 days 0:00:36.000
>>> This dump file has an exception of interest stored in it.
>>> The stored exception information can be accessed via .ecxr.
>>> (1468.17c4): Access violation - code c0000005 (first/second chance not
>>> available)
>>> *** WARNING: Unable to verify timestamp for ntdll.dll
>>> *** ERROR: Module load completed but symbols could not be loaded for
>>> ntdll.dll
>>> *** WARNING: Unable to verify timestamp for kernel32.dll
>>> kernel32.dll
>>> eax=00000000 ebx=0d980d78 ecx=0ee7a1d0 edx=00000265 esi=0d980d38
>>> edi=0043b8cc
>>> eip=77c30c32 esp=0043b58c ebp=0043b59c iopl=0         nv up ei pl zr na
>>> pe nc
>>> cs=0023  ss=002b  ds=002b  es=002b  fs=0053  gs=002b
>>> efl=00000246
>>> ntdll+0x20c32:
>>> 77c30c32 83c404          add     esp,4
>>> 0:000> The stored exception information can be accessed via .ecxr.
>>>        ^ No runnable debuggees error in 'The stored exception
>>> information can be accessed via .ecxr.'
>>> 0:000> (1468.17c4): Access violation - code c0000005 (first/second
>>> chance not available)
>>>        ^ Syntax error in '(1468.17c4): Access violation - code c0000005
>>> (first/second chance not available)'
>>> 0:000> !analayze -v
>>> No export analayze found
>>> 0:000> !analyze -v
>>> *                        Exception Analysis
>>> *** ERROR: Symbol file could not be found.  Defaulted to export symbols
>>> for spatialiteprovider.dll -
>>> for core.pyd -
>>> for qgis_gui.dll -
>>> ***** OS symbols are WRONG. Please fix symbols to do analysis.
>>> ***** OS (WOW64 kernel32) symbols are WRONG. Please fix symbols to do
>>> analysis.
>>> ***    Your debugger is not using the correct symbols                 ***
>>> ***    In order for this command to work properly, your symbol path   ***
>>> ***    must point to .pdb files that have full type information.      ***
>>> ***    Certain .pdb files (such as the public OS symbols) do not      ***
>>> ***    contain the required information.  Contact the group that      ***
>>> ***    provided you with these symbols if you need this command to    ***
>>> ***    work.                                                          ***
>>> ***    Type referenced: nt!IMAGE_NT_HEADERS32                         ***
>>> * Symbols can not be loaded because symbol path is not initialized. *
>>> * The Symbol Path can be set by:                                    *
>>> *   using the _NT_SYMBOL_PATH environment variable.                 *
>>> *   using the -y <symbol_path> argument when starting the debugger. *
>>> *   using .sympath and .sympath+                                    *
>>> Unable to load image C:\Windows\SysWOW64\KERNELBASE.dll, Win32 error 0n2
>>> *** WARNING: Unable to verify timestamp for KERNELBASE.dll
>>> KERNELBASE.dll
>>> for ole32.dll -
>>> for user32.dll -
>>> *** WARNING: Unable to verify timestamp for winmm.dll
>>> winmm.dll
>>> FAULTING_IP:
>>> QtCore4!QString::operator==+8
>>> 67053478 8b4a08          mov     ecx,dword ptr [edx+8]
>>> EXCEPTION_RECORD:  ffffffff -- (.exr 0xffffffffffffffff)
>>> ExceptionAddress: 67053478 (QtCore4!QString::operator==+0x00000008)
>>>    ExceptionCode: c0000005 (Access violation)
>>>   ExceptionFlags: 00000000
>>> NumberParameters: 2
>>>    Parameter[0]: 00000000
>>>    Parameter[1]: 0000026d
>>> Attempt to read from address 0000026d
>>> DEFAULT_BUCKET_ID:  WRONG_SYMBOLS
>>> PROCESS_NAME:  qgis-bin.exe
>>> ADDITIONAL_DEBUG_TEXT:
>>> You can run '.symfix; .reload' to try to fix the symbol path and load
>>> symbols.
>>> FAULTING_MODULE: 773c0000 kernel32
>>> DEBUG_FLR_IMAGE_TIMESTAMP:  53052dad
>>> MODULE_NAME: QtCore4
>>> ERROR_CODE: (NTSTATUS) 0xc0000005 - L'istruzione a 0x%08lx ha fatto
>>> riferimento alla memoria a 0x%08lx. La memoria non poteva essere %s.
>>> EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - L'istruzione a 0x%08lx ha fatto
>>> EXCEPTION_PARAMETER1:  00000000
>>> EXCEPTION_PARAMETER2:  0000026d
>>> READ_ADDRESS:  0000026d
>>> FOLLOWUP_IP:
>>> APP:  qgis-bin.exe
>>> PRIMARY_PROBLEM_CLASS:  WRONG_SYMBOLS
>>> BUGCHECK_STR:  APPLICATION_FAULT_WRONG_SYMBOLS
>>> LAST_CONTROL_TRANSFER:  from 6257b1dd to 67053478
>>> STACK_TEXT:
>>> WARNING: Stack unwind information not available. Following frames may be
>>> wrong.
>>> 0043c688 6257b1dd 0043c968 972e5cba 4052e5cb
>>> QtCore4!QString::operator==+0x8
>>> 0043c784 6252ceeb 0043c968 972e5cba 4052e5cb
>>> qgis_core!QgsSvgCache::svgAsImage+0x6d
>>> 0043c91c 6252d841 0e8d0358 0043c968 00000000
>>> qgis_core!QgsSVGFillSymbolLayer::applyPattern+0x11b
>>> 0043c9b4 6253ddcc 00000001 0000ffff 00000000
>>> qgis_core!QgsSVGFillSymbolLayer::applyDataDefinedSettings+0x4f1
>>> 0043c9e8 6252fc3d 0043caa4 9bbf786d 00000000
>>> qgis_core!QgsFeatureRendererV2::_getPolygon+0x36c
>>> 0043ca80 624ffd70 0043cafc 00000000 0043caa4
>>> qgis_core!QgsImageFillSymbolLayer::renderPolygon+0x6d
>>> 0043cac0 6253e593 0043cafc 00000000 05964f08
>>> qgis_core!QgsFillSymbolV2::renderPolygon+0xa0
>>> 0043cb04 5d30a9f6 0043cb14 0043cb74 6276ec24
>>> qgis_core!QgsFeatureRendererV2::renderFeatureWithSymbol+0x383
>>> 0043cb18 6255998d 6721175c 00000001 053948e0
>>> spatialiteprovider!selectWidget+0x6586
>>> 0043cb7c 6269e3d9 053948e0 9bbf7d91 053948e0
>>> qgis_core!QgsRuleBasedRendererV2::stopRender+0x10d
>>> 0043cc04 626aa880 0043ce04 053948e0 67055a00
>>> qgis_core!QgsVectorLayer::drawRendererV2+0x289
>>> 0043cdfc 67055a00 0ec829a0 0c622068 0e8e60a0
>>> qgis_core!QgsVectorLayer::draw+0x7b0
>>> 0043ce10 5cdd6f0b 3f800001 00000000 0043d018
>>> QtCore4!QString::localeAwareCompare+0x250
>>> 0043ce20 5cdd6f1f 053948e0 0043d03c 0e8e60a0
>>> core!OGREnvelope3D::Intersect+0x15f13b
>>> 0043d018 607bfbaa 0043d03c 00000000 9bbf61ae
>>> core!OGREnvelope3D::Intersect+0x15f14f
>>> 0043d06c 6081e600 05329f70 0043d0ec 60888574
>>> qgis_gui!QgsMapCanvasMap::render+0x10a
>>> 0043d080 607bb610 9bbf610e 0043d710 05329f70
>>> qgis_gui!QgsMapCanvas::renderStarting+0x10
>>> 0043d0f4 607bf11c 9bbf6082 0043d710 05329f70
>>> qgis_gui!QgsMapCanvas::refresh+0x1e0
>>> 00000000 00000000 00000000 00000000 00000000
>>> qgis_gui!QgsMapCanvas::wheelEvent+0x17c
>>> STACK_COMMAND:  ~0s; .ecxr ; kb
>>> SYMBOL_STACK_INDEX:  0
>>> SYMBOL_NAME:  qtcore4!QString::operator==+8
>>> FOLLOWUP_NAME:  MachineOwner
>>> IMAGE_NAME:  QtCore4.dll
>>> FAILURE_BUCKET_ID:
>>>  WRONG_SYMBOLS_c0000005_QtCore4.dll!QString::operator==
>>> Followup: MachineOwner
>>> 0:000> lmvm spatialiteprovider.dll
>>> start    end        module name
>>> 0:000> lmvm core.pyd
>>> 0:000> lmvm qgis_gui.dll
>>> 606d0000 609c6000   qgis_gui   (export symbols)       qgis_gui.dll
>>>     Loaded symbol image file: qgis_gui.dll
>>>     Mapped memory image file: C:\Program Files (x86)\QGIS
>>> Valmiera\apps\qgis\bin\qgis_gui.dll
>>>     Image path: C:\Program Files (x86)\QGIS
>>>     Image name: qgis_gui.dll
>>>     Timestamp:        Wed Feb 26 14:58:08 2014 (530DF2F0)
>>>     CheckSum:         00300642
>>>     ImageSize:        002F6000
>>>     File version:     0.0.0.0
>>>     Product version:  0.0.0.0
>>>     File flags:       0 (Mask 0)
>>>     File OS:          0 Unknown Base
>>>     File type:        0.0 Unknown
>>>     File date:        00000000.00000000
>>>     Translations:     0000.04b0 0000.04e4 0409.04b0 0409.04e4
>>> 0:000> lmvm core
>>> 5cc20000 5d0d1000   core       (export symbols)       core.pyd
>>>     Loaded symbol image file: core.pyd
>>> Valmiera\apps\qgis\python\qgis\core.pyd
>>>     Image name: core.pyd
>>>     Timestamp:        Wed Feb 26 14:56:22 2014 (530DF286)
>>>     CheckSum:         004AC88F
>>>     ImageSize:        004B1000
>>> 5d2f0000 5d335000   spatialiteprovider   (export symbols)
>>>     Loaded symbol image file: spatialiteprovider.dll
>>> Valmiera\apps\qgis\plugins\spatialiteprovider.dll
>>>     Image name: spatialiteprovider.dll
>>>     Timestamp:        Wed Feb 26 14:59:06 2014 (530DF32A)
>>>     CheckSum:         000471D6
>>>     ImageSize:        00045000
>>> any idea???
>>> thanks
>>> Enzo Cocca (PhD Candidate)
>>> Research Fellow
>>> Università di Napoli "L'Orientale"
>>> mail: enzo.ccc at gmail.com
>>> cell: +393495087014
>> Research Fellow
>> cell: +393495087014
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Giovanni Allegri
> http://about.me/giovanniallegri
> Twitter: https://twitter.com/_giohappy_
> blog: http://blog.spaziogis.it
> GEO+ geomatica in Italia http://bit.ly/GEOplus
Research Fellow
cell: +393495087014
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140307/9a014ded/attachment-0001.html>
