[Qgis-developer] Run stable and master versions of QGIS on Ubuntu
Etienne Tourigny
etourigny.dev at gmail.com
Mon Mar 10 13:26:59 PDT 2014
AFAIK, you have to build your own version (preferrably master) with a
different install prefix (e.g. /home/softdev/), and when you want to use
that version you need to add relevant paths to PATH and LD_LIBRARY_PATH.
I have a shell function that sets this up on demand:
setup_softdev()
export SOFT_PREFIX=/home/softdev
export LD_LIBRARY_PATH="/home/softdev/lib"
export LIBRARY_PATH=/home/softdev/lib
export LD_RUN_PATH=/home/softdev/lib
export PATH=/home/softdev/bin:$PATH
export CPLUS_INCLUDE_PATH=/home/softdev/include
export C_INCLUDE_PATH=/home/softdev/include
export CPPFLAGS=-I/home/softdev/include
export PYTHONPATH=/home/softdev/lib/python2.7/site-packages/
export GDAL_DATA=/home/softdev/share/gdal
export -f setup_softdev
On Mon, Mar 10, 2014 at 5:19 PM, Rémi Bovard <remi.bovard at gmail.com> wrote:
> Hi list,
> I'm wondering if there is there a simple way to run stable and master
> versions of QGIS on Ubuntu? By simple, I mean - if possible - without
> compile QGIS from source.
> For now, as described in doc [1], I edit /etc/apt/sources.list to define
> which repository to use : http://qgis.org/debian or
> http://qgis.org/debian-nightly. But doing like this, I cannot run the two
> versions at the same time.
> Thank you in advance for your answers.
> Rémi
> [1] http://qgis.org/en/site/forusers/alldownloads.html#ubuntu
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140310/ae3d22fe/attachment-0001.html>
