[Qgis-developer] Postgis Spatial Views - problems with primary	keys
    Alexandre Neto
    senhor.neto at gmail.com
    Tue Mar 11 05:08:51 PDT 2014
Hello all,
Regarding this matter, should I make a ticket? Or is the general
understanding that the described behavior is ok as it is?
Thanks,
Alexandre Neto
On Mon, Mar 10, 2014 at 2:39 PM, Alexandre Neto <senhor.neto at gmail.com>wrote:
> Hi Jürgen,
> On Mon, Mar 10, 2014 at 12:30 PM, Jürgen E. <jef at norbit.de> wrote:
>> QGIS just offers all integer fields as candidate.  It doesn't select any.
> If you use add Postgis layer dialog, it uses one of integer fields by
> default in the primary key column (not always the same).
>> I think that changed before 2.0.1. QGIS used to identify which view field
>> are
>> primary keys in the underlying tables, but that makes sense if the view
>> is a
>> selection of that table, which is just a very small subset of possible
>> views.
>> E.g. for joins between two tables being a primary key in one of the table,
>> doesn't mean that the attribute is also unique in the view.
> I have a Portuguese user that says that this 2.0.1 is working as before
> (and that he won't change to 2.2 until it gets "fixed"), but personally I
> can't confirm this.
> What was the downside of the later behavior? I.e. qgis identifying several
> primary keys and try to guess what to use? Even if it is a small subset of
> possible views, I think it would make user's life easier in some cases.
> Also, as it is now, unless the view only have one integer field, the
> browser became useless for adding views. We should, at least, change the
> error message, informing the user that he must select a primary key
> manually (only possible in the add postgis layer dialog).
> Thanks for your answer.
> Alexandre
>> Jürgen
>> Jürgen E. Fischer         norBIT GmbH               Tel.
>> +49-4931-918175-31
>> Dipl.-Inf. (FH)           Rheinstraße 13            Fax.
>> +49-4931-918175-50
>> Software Engineer         D-26506 Norden
>> http://www.norbit.de
>> QGIS PSC member (RM)      Germany                      IRC: jef on
>> FreeNode
>> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
>> Rheinstrasse 13, 26506 Norden
>> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140311/88497ba8/attachment.html>
