[Qgis-developer] how to run an external program from QGIS and catch its output?
Larry Shaffer
larrys at dakotacarto.com
Tue Mar 18 08:44:05 PDT 2014
Hi Hugo,
On Tue, Mar 18, 2014 at 2:59 AM, Hugo Ledoux <h.ledoux at tudelft.nl> wrote:
> I'm developing a plugin and I want to call an external program that
> takes as input a string and outputs a string. Under Mac and Linux I
> successfully used subprocess.Popen() but under Windows it doesn't
> work. For instance, from a Python console inside QGIS under Mac/Linux:
> import subprocess
> p = subprocess.Popen(['ls', '-al'], stdout=subprocess.PIPE)
> print p.stdout.read()
Though I have not tested whether this is better on Windows, try instead:
print p.communicate()[0]
See:
http://docs.python.org/2.7/library/subprocess.html#subprocess.Popen.communicate
I had a similar file handle issues on Mac, and that fixed it (though it
seems like p.stdout.read() should just work).
Regards,
Larry
> But under Windows if I try to catch the output (which is a requirement for
> me) :
> import subprocess
> p = subprocess.Popen(['dir'], shell=True, stdout=subprocess.PIPE)
> File "<input>", line 1, in <module>
> File "C:\PROGRA~1\QGISVA~1\apps\Python27\lib\subprocess.py", line
> 703, in __init__
> errread, errwrite) = self._get_handles(stdin, stdout, stderr)
> 839, in _get_handles
> p2cread = self._make_inheritable(p2cread)
> 878, in _make_inheritable
> _subprocess.DUPLICATE_SAME_ACCESS)
> WindowsError: [Error 6] The handle is invalid
> What's the best way to call a program and catching the output (a
> string) under Windows?
> Many thanks,
> Hugo
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140318/85cff827/attachment.html>
