[Qgis-developer] WMS load regression in 2.2
Nyall Dawson
nyall.dawson at gmail.com
Tue Mar 18 14:58:03 PDT 2014
On 17 March 2014 23:56, Luca Manganelli <luca76 at gmail.com> wrote:
> on 32 bit Windows XP systems, loading WMS layers in QGIS 2.2 are
> considerately slower than in QGIS 2.0.
> On my tests, QGIS 2.2 takes more than a minute, while QGIS 2.0 loads the WMS
> in 1-2 seconds.
> To test, you can use our WMS server:
> http://webapps.comune.trento.it/ogc
Have you made a change to your WMS server? I can't replicate this -
for me loading the server in 2.2 32 bit only takes a few seconds.
However, I suspect that you may be encountering an issue I ran into
with connections to a WMS with many layers. This was fixed in
https://github.com/qgis/QGIS/commit/99d030d67594766c5acb452adb84cc0f803f201d
. I'm planning on backporting this fix to the 2.2 branch too so it
will be included in any potential 2.2 point releases.
Are you able to test with the current master dev version and report
your findings?
Nyall
