[Qgis-developer] Crash when launching globe
Paolo Cavallini
cavallini at faunalia.it
Wed Mar 19 08:56:49 PDT 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi all.
As soon as I launch Globe, without having configured it, QGIS crashes.
Master, just recompliled.
Anyone confirms?
All the best.
[osgEarth]* WARNING: Failed to load terrain engine driver for "mp"
[osgEarth]* FAILED to create a terrain engine for this map
[osgEarth]* [CacheFactory] Failed to load cache plugin for type "filesystem"
QGIS died on signal 11
warning: Could not load shared library symbols for linux-vdso.so.1.
Do you need "set solib-search-path" or "set sysroot"?
[New LWP 24618]
[New LWP 24617]
[New LWP 24614]
[New LWP 24613]
[New LWP 24604]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
warning: no loadable sections found in added symbol-file system-supplied DSO at
0x7ffff99d7000
0x00007f432d5b4cf9 in __libc_waitpid (pid=24620, stat_loc=0x7ffff994647c, options=0)
at ../sysdeps/unix/sysv/linux/waitpid.c:40
40 ../sysdeps/unix/sysv/linux/waitpid.c: File o directory non esistente.
[Current thread is 1 (Thread 0x7f4334e1d7c0 (LWP 24603))]
#0 0x00007f432d5b4cf9 in __libc_waitpid (pid=24620, stat_loc=0x7ffff994647c,
options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:40
resultvar = 117043536
oldtype = 0
#1 0x00000000004f7f17 in qgisCrash(int) ()
No symbol table info available.
#2 <signal handler called>
No locals.
#3 0x00007f430dc28039 in osgEarth::MapNode::getTerrain() () from
/usr/lib/libosgEarth.so.2
#4 0x00007f430d4d6418 in osgEarth::Util::EarthManipulator::established() () from
/usr/lib/libosgEarthUtil.so.2
#5 0x00007f430dfa3d29 in osgViewer::View::assignSceneDataToCameras() () from
/usr/lib/libosgViewer.so.99
#6 0x00007f430dfa40ff in osgViewer::View::setSceneData(osg::Node*) () from
#7 0x00007f430f574c6a in GlobePlugin::run() () from
/usr/lib/qgis/plugins/libglobeplugin.so
#8 0x00007f430f589d75 in ?? () from /usr/lib/qgis/plugins/libglobeplugin.so
#9 0x00007f43306c077a in QMetaObject::activate(QObject*, QMetaObject const*, int,
void**) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#10 0x00007f432fa47572 in QAction::triggered(bool) () from
/usr/lib/x86_64-linux-gnu/libQtGui.so.4
#11 0x00007f432fa48f43 in QAction::activate(QAction::ActionEvent) () from
#12 0x00007f432fe732f9 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#13 0x00007f432fe77829 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#14 0x00007f432fa9cc9a in QWidget::event(QEvent*) () from
#15 0x00007f432fe7b62b in QMenu::event(QEvent*) () from
#16 0x00007f432fa4d6cc in QApplicationPrivate::notify_helper(QObject*, QEvent*) ()
#17 0x00007f432fa53e7d in QApplication::notify(QObject*, QEvent*) () from
#18 0x00007f43318e5feb in QgsApplication::notify(QObject*, QEvent*) () from
/usr/lib/libqgis_core.so.2.3.0
#19 0x00007f43306ac4ed in QCoreApplication::notifyInternal(QObject*, QEvent*) () from
#20 0x00007f432fa53633 in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*,
QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) () from
#21 0x00007f432fac562c in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#22 0x00007f432fac3d6c in QApplication::x11ProcessEvent(_XEvent*) () from
#23 0x00007f432faeb6c2 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#24 0x00007f432be2f526 in g_main_context_dispatch () from
/lib/x86_64-linux-gnu/libglib-2.0.so.0
#25 0x00007f432be2f878 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#26 0x00007f432be2f91c in g_main_context_iteration () from
#27 0x00007f43306d9725 in
QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from
#28 0x00007f432faeb776 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#29 0x00007f43306ab0bf in
QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from
#30 0x00007f43306ab3b5 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) ()
#31 0x00007f43306b0b89 in QCoreApplication::exec() () from
#32 0x00000000004f28f3 in main ()
gdb returned 0
Paolo Cavallini - www.faunalia.eu
Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
Comment: Using GnuPG with Icedove - http://www.enigmail.net/
iEYEARECAAYFAlMpvkAACgkQ/NedwLUzIr7F+gCeK85AASv2NU+cqGTY0nekGvcC
KWEAnRREDN2IRmm2ESZ6u+YknykUltvq
=ZwIm
-----END PGP SIGNATURE-----
