[Qgis-developer] auto aligning adjoining features
Zoltan Szecsei
zoltans at geograph.co.za
Thu Mar 20 01:58:29 PDT 2014
Hi Dev list,
Is anyone aware of a plugin that can:
* auto-snap (make concurrent) borders between adjoining polygons
(perhaps also in different map-layers)
(Like topologically aligning cultivated land polygons with river
banks or other adjoining polygon features)
* auto-snap (make concurrent) polygons borders with line features
(Like topologically aligning cultivated land polygons with road or
other line features)
* Drop in vertices at places where features intersect each other
Like a road crossing a field (but not dividing the field into two
pieces), or a bridge feature running on top of a road feature
(placing vertices on the road feature directly under the start &
endpoints of the bridge line)
It would be cool if this could be automated, with the ability to set
snapping tolerances, and choosing whether to have a master feature set
to move to, or to average the gap between the features (ie: move both
features to the averaged common boundary). The final result must have
identical vertices in both the adjoining features even if they are in
separate maps, and the ability to set a master (aka unmoveable) feature
is critical in case you need to align more than 2 features (eg:
Municipal boundary with cultivated land with road), as you would not
want a previously aligned feature set to "walk" whilst you are aligning
a further feature set to it.
Thanks & chat soon,
Zoltan
Zoltan Szecsei PrGISc [PGP0031]
Geograph (Pty) Ltd.
GIS and Photogrammetric Services
P.O. Box 7, Muizenberg 7950, South Africa.
Mobile: +27-83-6004028
Fax: +27-86-6115323 www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140320/6b53b32f/attachment.html>
