[Qgis-developer] problem with custom UI feature form with dates
Hugo Mercier
hugo.mercier at oslandia.com
Thu Mar 20 07:11:41 PDT 2014
Le 20/03/2014 14:18, Denis Rouzaud a écrit :
> Hi all,
> I have noticed some problem with custom feature forms when using dates.
> In my form I use a QDateEdit.
> If I leave the field in QGIs as line edit, the date is not set in the
> widget.
> If I set the field as calendar, it messes up the form.
> Here it is in picture: http://imgur.com/a/X7chU
> Is there any way to use QDateEdit???
> Cheers,
Hi Denis,
I've had the same issue here.
After looking at the code, a QCalendar object is needed for a date
field. There is no support for QDateEdit.
Hugo Mercier
Oslandia
