[Qgis-developer] problem with custom UI feature form with dates
Denis Rouzaud
denis.rouzaud at gmail.com
Thu Mar 20 07:54:38 PDT 2014
I will give a try (again) at the new editor widgets !
On 20. 03. 14 15:29, Matthias Kuhn wrote:
> Or you could just tell me to include this in the refactoring work ;-)
> Best
> Matthias
> On Thu 20 Mar 2014 03:17:45 PM CET, Denis Rouzaud wrote:
>> OK, thanks!
>> one more thing for the HF ;)
>> On 20. 03. 14 15:11, Hugo Mercier wrote:
>>> Le 20/03/2014 14:18, Denis Rouzaud a écrit :
>>>> Hi all,
>>>> I have noticed some problem with custom feature forms when using
>>>> dates.
>>>> In my form I use a QDateEdit.
>>>> If I leave the field in QGIs as line edit, the date is not set in the
>>>> widget.
>>>> If I set the field as calendar, it messes up the form.
>>>> Here it is in picture: http://imgur.com/a/X7chU
>>>> Is there any way to use QDateEdit???
>>>> Cheers,
>>> Hi Denis,
>>> I've had the same issue here.
>>> After looking at the code, a QCalendar object is needed for a date
>>> field. There is no support for QDateEdit.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
