[Qgis-developer] Qgis-Processing (former Sextante) has two bug trackers
Alexander Bruy alexander.bruy at gmail.com
Mon Mar 24 05:48:06 PDT 2014
I raised this issue twice some time ago, see [0, 1].
Also if I'm not wrong same issue was raised by Paolo too.
[0] http://lists.osgeo.org/pipermail/qgis-developer/2013-August/027973.html
[1] http://lists.osgeo.org/pipermail/qgis-developer/2013-September/028585.html
2014-03-24 14:10 GMT+02:00 Filipe Dias <filipesdias at gmail.com>:
> Hi
> QGIS-Processing (former Sextante) has open tickets on two bugtrackers:
> - the plugin bug tracker, built when it was a plugin, but with a lot of
> active tickets -> http://hub.qgis.org/projects/sextante/activity
> - the main bug tracker with a few open tickets ->
> http://hub.qgis.org/projects/quantum-gis/issues
> I understand those two can't be merged in one go, because the
> plugin-bugtracker has categories (QGIS-Processing SAGA GIS, QGIS-Processing
> GRASS GIS etc) that don't fit in the main bug tracker. But this should be
> solved ASAP, because the current situation is quite confusing
> Regards
> F.
> Qgis-developer mailing list
Alexander Bruy
