[Qgis-developer] Qgis-Processing (former Sextante) has two bug trackers
Filipe Dias
filipesdias at gmail.com
Mon Mar 24 12:05:34 PDT 2014
Hi
I think Processing tickets should be in the main bug tracker, since GDAL
tools, fTools and Grass plugin tickets are also there.
Also, Qgis-Processing is a really big (and great) feature, that interests a
lot of users, so it makes sense to keep its tickets in the main tracker.
Regards
F.
On Mon, Mar 24, 2014 at 6:02 PM, Alex Mandel <tech_dev at wildintellect.com>wrote:
> On 03/24/2014 05:10 AM, Filipe Dias wrote:
> > Hi
> > QGIS-Processing (former Sextante) has open tickets on two bugtrackers:
> > - the plugin bug tracker, built when it was a plugin, but with a lot of
> > active tickets -> http://hub.qgis.org/projects/sextante/activity
> > - the main bug tracker with a few open tickets ->
> > http://hub.qgis.org/projects/quantum-gis/issues
> > I understand those two can't be merged in one go, because the
> > plugin-bugtracker has categories (QGIS-Processing SAGA GIS,
> QGIS-Processing
> > GRASS GIS etc) that don't fit in the main bug tracker. But this should be
> > solved ASAP, because the current situation is quite confusing
> > Regards
> > F.
> I'm of the opinion that the tracker should continue to be the Plugin
> tracker, not the main QGIS tracker. So I'd propse moving any
> Sextante/Processing tickets from the main or linking them into the
> Plugin tracker.
> To me it's still a plugin, just a core plugin but big enough that it's
> really a subproject. If we wanted to move the Plugin tracker as a
> sub-project of QGIS that would also make sense.
> Also Processing bugs aside from Processing not loading aren't
> showstoppers for release.
> Thanks,
> Alex
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140324/478d877b/attachment.html>
