[Qgis-developer] Debugging Python plugin with Eclipse: breakpoints do not wotk
Francesco Sozzi
fsozzi at intercad.ch
Tue Mar 25 01:39:59 PDT 2014
Hi Everybody,
I'm new on QGis developing and Python and I'm trying to setup a developing
environment for building plugins on QGis.
My problem is that breakpoints on Eclipse do not work, process does not stop
on them.
This is what I do to debug:
1) On Eclipse I execute PyDev->Start Debug Server
2) On QGis I press "Remote Debug" button
3) On Eclipse I then see, under "Debug Server [Python Server]", a new node
named "unknown"
This is what I do to setup plugin and Eclipse project:
1) on C:\Program Files\QGIS Valmiera\apps\qgis\python\plugins I've created a
folder named "MyFisrtPlugin" with all files I need for a basic test.
This test work fine in QGis
Code is nested by use of TAB
2) on Eclispe I've created a new PyDev project with
- Directory = c:\app\Eclipse\Workspace\MyFirstPlugin
- grammar version = 2.7
- Interpreter = Python 2.7
- Create links to existing sources
- Project External Source Folders = C:\Program Files\QGIS
Valmiera\apps\qgis\python\plugins\MyFirstPlugin
- Referenced projects = none
Here you are in detail what I've done for installing and setup:
- I use Windows 7 64 bit
- I use QGis 2.2
- I've installed PyDev on Eclipse
- Help->"Install new software" set "http://pydev.org/updates" and
install PyDev
- I've configured PyDev on Eclipse
- Windows->Preferences choose page PyDev->Interpreters->Python
Interpreter, press "new" and set
- Python 2.7
- C:\Program Files\QGIS Valmiera\bin\python.exe
- I've installed on QGis "Plugin reloader" and "Plugin builder"
- Plugin->"Manage and install plugin"
- Settings: check "show also experimental plugin"
- search for "remote debug" and install (I did not find, check the
following section on how to install)
- search for "plugin reloader" and install
- search for "plugin builder" and install
- I've installed on QGis "Remote Debug" (it is not reachable by
Plugin->"Manage and install plugin")
- download from https://github.com/sourcepole/qgis-remote-debug
- copy RemoteDebug folder to C:\Program Files\QGIS
- I've enabled Eclipse debugging:
- create a general project
- go to debug perspective
- PyDev->Start debug Server
- Open QGis and start Debug Remote
- I've made Eclipse understanding QGis API
- Click Window=>Preferences=>PyDev=>Interpreter - Python
- press "New folder" on Library tab
- add C:\Program Files\QGIS Valmiera\apps\qgis\python
- to enable pyrcc4 and pyuic4 I've set Windows system variables
- PYTHONHOME = C:\Program Files\QGIS Valmiera\apps\Python27
- PYTHONPATH = C:\Program Files\QGIS Valmiera\apps\Python27\Lib
Any suggestion?...
Best regards
Franz
