[Qgis-developer] Debugging Python plugin with Eclipse: breakpoints do not wotk
Gino Pirelli luipir at gmail.com
Tue Mar 25 09:44:23 PDT 2014
just a note... there's no alternative RemoteDebug plugin... my changes
where merged in the main project
https://github.com/sourcepole/qgis-remote-debug
In my case it works... now I can't rememnber If I set something particular
(and I've no time to check now)... what I can say is that remote debug
plugin connect pydev server only if it is strictly clearly started...
otherwise sometimes it does nothing.
so my procedure is... running pydev debug server... then start qgis... then
start remotedebug plugin then I start to debug
see you Luigi Pirelli
On 25 March 2014 14:34, Franz1965 <fsozzi at intercad.ch> wrote:
> I've also taken a try with an alternate RemoteDebug plugin
> (https://github.com/luipir/qgis-remote-debug) but with no luck.
> It's strange... RemoteDebug is not in the list of installable plugins and
> you have to manually download and install it. But on downloaded version,
> inside metadata.txt, I find qgisMaximumVersion=2.99; so I guess that it
> should be compatible.
> http://osgeo-org.1560.x6.nabble.com/Debugging-Python-plugin-with-Eclipse-breakpoints-do-not-wotk-tp5130877p5130945.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140325/16a4841a/attachment.html>
