[Qgis-developer] processing.runalg() issue with grass algorithms
Eric Goddard egoddard1010 at gmail.com
Tue Mar 25 19:15:37 PDT 2014
Thanks, I knew they returned dictionaries, but I forgot to change the
call to runalg to have lpf as the output argument. The script executes
with the SAGA algorithm.
On Tue, Mar 25, 2014 at 5:25 PM, Victor Olaya <volayaf at gmail.com> wrote:
> The runalg method does not return a layer. It returns a dict with the
> outputs of the algorithms. Keys are output names, values are paths to
> output objects
> Hope this helps
> 2014-03-25 22:36 GMT+01:00 Eric Goddard <egoddard1010 at gmail.com>:
>> Alright, latest master (9e42c5b), with processing version
>> 2.0-20131120. Running a custom tool that consists of the following
>> code results in an error:
>> ##dem=raster
>> ##radius=number 4
>> ##lpf=output raster
>> lpf = processing.runalg("saga:simplefilter", dem, 0, 0, radius, None)
>> An error has occured while executing Python code:
>> Traceback (most recent call last):
>>   File "/home/eric/.qgis2/python/plugins/processing/gui/AlgorithmExecutionDialog.py",
>> line 256, in accept
>>     self.finish()
>> line 281, in finish
>>     Postprocessing.handleAlgorithmResults(self.alg, self, not keepOpen)
>>   File "/home/eric/.qgis2/python/plugins/processing/gui/Postprocessing.py",
>> line 77, in handleAlgorithmResults
>>     dlg = CouldNotLoadResultsDialog(wrongLayers, alg)
>>   File "/home/eric/.qgis2/python/plugins/processing/gui/CouldNotLoadResultsDialog.py",
>> line 41, in __init__
>>     self.setupUi()
>> line 50, in setupUi
>>     html = self.alg.getPostProcessingErrorMessage(self.wrongLayers)
>>   File "/home/eric/.qgis2/python/plugins/processing/core/GeoAlgorithm.py",
>> line 520, in getPostProcessingErrorMessage
>>     + layer.value + '\n'
>> TypeError: cannot concatenate 'str' and 'dict' objects
>> Python version:
>> 2.7.6 (default, Feb 26 2014, 12:07:17)
>> [GCC 4.8.2 20140206 (prerelease)]
>> QGIS version:
>> 2.3.0-Master Master, 9e42c5b
>> Python path: ['/home/eric/.qgis2/python/plugins/processing',
>> '/usr/share/qgis/python', u'/home/eric/.qgis2/python',
>> u'/home/eric/.qgis2/python/plugins', '/usr/share/qgis/python/plugins',
>> '/usr/lib/python27.zip', '/usr/lib/python2.7',
>> '/usr/lib/python2.7/plat-linux2', '/usr/lib/python2.7/lib-tk',
>> '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload',
>> '/usr/lib/python2.7/site-packages',
>> '/usr/lib/python2.7/site-packages/gtk-2.0',
>> '/usr/lib/python2.7/site-packages/wx-3.0-gtk2',
>> '/usr/share/qgis/python/plugins/fTools/tools', '/home/eric/Documents']
>> Running the code in the console completes successfully. However, I'm
>> still unable to run a grass algorithm when the grass_region_parameter
>> and grass_region_cellsize_parameter are set to None.
>> Thanks,
>> Eric
>> On Mon, Mar 24, 2014 at 10:13 PM, Eric Goddard <egoddard1010 at gmail.com> wrote:
>>> Oops, my mistake. I have ##lrm=output raster in the header, but lpf = ... Is
>>> the only line in my code.
>>> I don't get the error message after changing lrm to lpf in the header. I do
>>> get another error message, but I think I broke my processing by trying to
>>> force an update. I'll test it tomorrow. Sorry about the confusion!
>>> Eric
>>> On Mar 22, 2014 5:06 PM, "Eric Goddard" <egoddard1010 at gmail.com> wrote:
>>>> Ah, I didn't know a file could he specified without a path. Thanks for the
>>>> clarification!
>>>> On Mar 22, 2014 4:37 PM, "Victor Olaya" <volayaf at gmail.com> wrote:
>>>>> > If I run the same line in the python console, it works correctly:
>>>>> >>>> radius = 4
>>>>> >>>> lpf = processing.runalg("saga:simplefilter", "SR_50M_alaska_nad", 0,
>>>>> >>>> 0, radius, None)
>>>>> >>>> processing.load(lpf['RESULT'])
>>>>> > Results in the map being loaded.
>>>>> Not sure why this is happening. I will try to reproduce the error and
>>>>> see if it can be fixed
>>>>> Thanks for the report
>>>>> > Also, if I change the output folder in the processing settings to a
>>>>> > different location (in this case, tmp/processing in my home folder)
>>>>> > and run another algorithm in the python console, the RESULT key still
>>>>> > points to /tmp/processing/...
>>>>> This is not a bug. If you do not enter a filename, the output will
>>>>> always go to a temporary file. The output folder that yu can set in
>>>>> the settings  is the folder to be used when you enter a filename
>>>>> without a path (like "myfile.shp", but not "/home/myuser/myfile.shp"),
>>>>> not the folder to use for temporary files.
>>>>> Thanks again!
