[Qgis-developer] GRASS & QGIS: the future
Bernhard Ströbl
bernhard.stroebl at jena.de
Thu Mar 27 04:12:15 PDT 2014
Hi Paolo,
my QGIS/GRASS usage is as follows:
1) To process in GRASS I I do neither use the plugin nor processing but
"native" GRASS
2) I use the plugin to visualize the results, especially together with
data in other formats (shp, raster) which I otherwise had to import into
3) I use processing but not with GRASS processes.
So I would propose a third way which negotiates between the two ways
porposed by you:
* upgrade processing and reduce the plugin to those features not covered
by processing (visualization, digitizing ...)
IMHO if someone wants fast processing with GRASS modules he should do it
in GRASS, if automation is needed a shell script is the way to go, so no
need to change processing in the proposed way (no export/import if
consecutive GRASS operations), though this would be nice to have, of
course :)
If there are many persons out there that use processing for consecutive
GRASS processes and think this is too slow and are not capable of doing
it in GRASS, please step forward!
my 2 cents
Bernhard
Am 27.03.2014 11:18, schrieb Paolo Cavallini:
> Hi all.
> I learned during dinner that GRASS7 RC1 is due very soon. This opens the
> issue of its functioning in QGIS. IMHO:
> * the qgis-grass-plugin might stop working (this has to be tested)
> * some of the module options will be different
> * new modules will not be available in QGIS.
> I think we can deal with this in several ways:
> * dropping the plugin, and concentrate the work on Processing
> * upgrading both the plugin and Processing.
> In the first case, we have two major issues:
> * upgrading Processing GRASS modules
> * changing the current Processing behaviour, avoiding the import-export
> phase when piping consecutive GRASS commands; this makes GRASS modules
> slower than the equivalent commands of other backends.
> While the first issue can be solved easily by a couple of people in a
> few days, the second one is more tricky, and requires hard coding skills.
> In addition, we'll no longer be able to edit GRASS vectors directly.
> In the second case, we'll have more work, and a not-so-nice duplication.
> I would like to have an open discussion on this, avoiding things to just
> happen, with the possible negative consequences.
> All the best.
__________ Information from ESET Security, version of virus signature database 9601 (20140327) __________
The message was checked by ESET Security.
part000.txt - is OK
http://www.eset.com
