[Qgis-developer] Building on OSX with brew
Tim Sutton
lists at linfiniti.com
Thu Mar 27 04:57:55 PDT 2014
Hi Larry
I finally have the time to sit down and try to get your recipe for building
/ debugging QGIS under QtCreator a try, but I cant seem to find your notes
on this. I have two screenies showing some of the settings but not quite
enough info to get it working. Currently I am getting this (see [2] below)
output when trying to run cmake in QtCreator. I am building using options
in [1].
I also made this dirty hack so that some python libs could be found [3].
Can you point me in the right direction of any notes etc you have?
Regards
Tim
[1]
-DCMAKE_INSTALL_PREFIX="/Users/timlinux/Applications/"
-DCMAKE_BUILD_TYPE="RelWithDebInfo" -DWITH_ASTYLE=FALSE
-DENABLE_TESTS=TRUE -DWITH_INTERNAL_SPATIALITE=FALSE
-DWITH_PYSPATIALITE=FALSE
-DSPATIALINDEX_INCLUDE_DIR=/usr/local/include/spatialindex
-DSPATIALINDEX_LIBRARY=/usr/local/Cellar/libspatialite/4.1.1/libspatialindex.dylib
-DQWT_LIBRARY=/usr/local/Cellar/qwt/6.1.0/lib/qwt.framework/Versions/Current/qwt
-DQWT_INCLUDE_DIR=/usr/local/Cellar/qwt/6.1.0/lib/qwt.framework/Versions/Current/Headers/
-DBISON_EXECUTABLE=/usr/local/Cellar/bison/3.0.2/bin/bison
-DWITH_MAPSERVER=TRUE -DWITH_APIDOC=FALSE -DQGIS_MACAPP_BUNDLE=2
-DSIP_BINARY_PATH=/usr/local/bin
-DPYTHON_LIBRARIES=/Library/Frameworks/Python.framework/Versions/2.7/lib/libpython2.7.dylib
-DWITH_MAPSERVER=False
[2]
CMake Error: The following variables are used in this project, but they are
set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake
files:
QWTPOLAR_INCLUDE_DIR
used as include directory in directory /Users/timlinux/dev/cpp/QGIS/src/app
QWTPOLAR_LIBRARY
linked by target "QGIS" in directory /Users/timlinux/dev/cpp/QGIS/src/app
linked by target "qgis_app" in directory
linked by target "qgis_qgisappclipboard" in directory
/Users/timlinux/dev/cpp/QGIS/tests/src/app
/usr/bin/python: can't open file '_find_qsci_py-NOTFOUND': [Errno 2] No
such file or directory
/usr/bin/python: can't open file '_find_pyqt_py-NOTFOUND': [Errno 2] No
-- QGIS version: 2.3.0 Master (20300)
-- Could not find GRASS
-- Found Proj: /usr/local/lib/libproj.dylib
-- Found GEOS: /usr/local/Cellar/geos/3.4.2/lib/libgeos_c.dylib
-- Found GDAL: /usr/local/Cellar/gdal/1.10.1/lib/libgdal.dylib (1.10.1)
-- Found Expat: /usr/local/lib/libexpat.dylib
-- Found Spatialindex:
-- Found Qwt:
/usr/local/Cellar/qwt/6.1.0/lib/qwt.framework/Versions/Current/qwt (6.1.0)
-- Found Sqlite3: /usr/lib/libsqlite3.dylib
-- Found PostgreSQL: /usr/local/Cellar/postgresql/9.3.2/lib/libpq.dylib
-- Found SpatiaLite: /usr/local/lib/libspatialite.dylib
-- Found Qt version: 4.8.6
-- Touch support disabled
-- Found QScintilla2: /usr/local/lib/libqscintilla2.dylib (2.8)
-- Pedantic compiler settings enabled
-- Debug output enabled
-- Found Python executable: /usr/bin/python
-- Found Python version: 2.7.5
-- Found Python library: -framework Python
-- Found SIP version: 4.15.4
-- Found GSL: -L/usr/local/Cellar/gsl/1.16/lib -lgsl -lgslcblas
-- txt2tags not found - disabled
-- Ctest Binary Directory set to:
/Users/timlinux/dev/cpp/QGIS/build-osx/output/bin
-- Configuring incomplete, errors occurred!
See also
"/Users/timlinux/dev/cpp/QGIS/build-osx/CMakeFiles/CMakeOutput.log".
See also "/Users/timlinux/dev/cpp/QGIS/build-osx/CMakeFiles/CMakeError.log".
[3]
Tims-MacBook-Pro:QGIS timlinux$ git diff
diff --git a/cmake/FindPyQt.py b/cmake/FindPyQt.py
index 256c4a6..b658cde 100644
--- a/cmake/FindPyQt.py
+++ b/cmake/FindPyQt.py
@@ -29,6 +29,7 @@
# Copyright (c) 2007, Simon Edwards <simon at simonzone.com>
# Redistribution and use is allowed according to the terms of the BSD
license.
# For details see the accompanying COPYING-CMAKE-SCRIPTS file.
+import sys
import PyQt4.pyqtconfig
diff --git a/cmake/FindSIP.py b/cmake/FindSIP.py
index e291baa..7eb8d68 100644
--- a/cmake/FindSIP.py
+++ b/cmake/FindSIP.py
@@ -31,6 +31,8 @@
import sys
+sys.path.append('/usr/local/lib/python2.7/site-packages/')
+print sys.path
import sipconfig
sipcfg = sipconfig.Configuration()
Tim Sutton - QGIS Project Steering Committee Member
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140327/618ab9bb/attachment-0001.html>
