[Qgis-developer] QGIS master crashes on zoom in - zoom out
Pedro Venâncio
pedrongvenancio at yahoo.com
Thu May 1 03:23:14 PDT 2014
I continue with this crash (report attached), with today's master...
Any hint?
Thanks!
Best regards,
Pedro
----- Mensagem original -----
> DE: Pedro Venâncio
> I just recompiled QGIS 2.2 and everything works fine. So, the problem is only
> with the master.
>> DE: Pedro Venâncio
>> Hi,
>> I've compiled and installed yesterday QGIS 2.3 master, on Xubuntu
> 12.04, but
>> it is continually crashing with a segmentation fault (core dumped). I just
> load
>> a layer (raster / shape / postgis) and do some zoom in / zoom out. I've
>> tried with the option to render with all processor cores active /
> deactivated,
>> but it happens exactly the same. I've also uninstalled the CADInput
> plugin,
>> because I read somewhere that it could give problems, but not resolved.
>> On the console::
>> $ qgis
>> Warning: loading of qt translation failed
> [/usr/share/qt4/translations/qt_en_US]
>> Warning: QGraphicsScene::addItem: item has already been added to this scene
>> no need
>> false; DefaultProxy; ; ; ; *********;
>> breaking!
>> breaking!
>> breaking!
>> breaking!
>> breaking!
>> breaking!
>> breaking!
>> breaking!
>> breaking!
>> breaking!
>> breaking!
>> breaking!
>> breaking!
>> breaking!
>> breaking!
>> breaking!
>> breaking!
>> Segmentation fault (core dumped)
>> The faster I zoom in / zoom out, more "breaking!" appears, until
> the
>> Segmentation fault... See here:
>> https://dl.dropboxusercontent.com/u/5772257/qgis/crash.ogv
>> https://dl.dropboxusercontent.com/u/5772257/qgis/crash_nightly.ogv
>> In the first attempt I was using the ubuntugis-stable repository, with gdal
>> 1.9.x. However, I updated all packages with ubuntugis-unstable, and went
> back to
>> compile, but the same thing happens.
>> In a last attempt, I tried the nightly builds, also without success.
>> I've uninstalled everything that was associated with qgis, grass, gdal;
>> erased folders .qgis2 and .config/QGIS, but still crashes...
>> Error reports always refer to something related to QgsMapRenderer: SIGSEGV
> in
>> QgsMapRenderer::extent() / QgsMapRenderer::updateScale() /
>> QgsMapRenderer::adjustExtentToSize():
>> https://dl.dropboxusercontent.com/u/5772257/qgis/relatorio_erro_qgis.png
>> https://dl.dropboxusercontent.com/u/5772257/qgis/relatorio_erro_qgis_2.png
>> https://dl.dropboxusercontent.com/u/5772257/qgis/relatorio_erro_qgis_3.png
>> Does anyone have any idea about what may be the cause?
>> Thank you very much!
>> Best regards,
>> Pedro
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140501/23c31c23/attachment-0001.jpg>
