[Qgis-developer] QGIS custom widgets library for Qt designer: python/cpp availability
Denis Rouzaud
denis.rouzaud at gmail.com
Fri May 2 01:42:09 PDT 2014
Hi all,
I have been creating a new library for having QGIS custom widgets
available in Qt Designer, see PR 1325 [0].
I am facing a problem regarding the included file name that is defined
in the custom widget and used by uic to create the code for it [1].
The problem is that this file won't be the same if the UI will be
compiled from python or from c++.
For example, QgsMapLayerComboBoxPlugin [2], would need to include
qgsmaplayercombobox.h [3] for c++ while it waits for qgis.gui for Python.
Does someone has any idea if it would be possible to make the widget
librabry working for both languages?
The non-optimal solutions I see:
* provide two libraries, one for python and one for c++
* add a setting in cmake to choose to compile custom widgets for C++ or
for python
* choose one by default and let the user change in source the included file
I think that all of these are non satisfying and removes all the magic
from this new feature.
If you have any lead, it's more than welcome.
Cheers,
Denis
[0] https://github.com/qgis/QGIS/pull/1325
[1]
http://qt-project.org/doc/qt-4.8/qdesignercustomwidgetinterface.html#includeFile
[2] https://github.com/qgis/QGIS/pull/1325/files#diff-15
[3] http://qgis.org/api/classQgsMapLayerComboBox.html
