[Qgis-developer] error starting qgis (built from source)
    chris marx
    chrismarx at gmail.com
    Fri May  2 12:47:06 PDT 2014
I followed the instructions here:
https://raw.githubusercontent.com/qgis/QGIS/master/INSTALL
and did the build on a clean ubuntu 12.04 64bit vm. the only thing i
changed from the vanilla build was to enable WITH_ORACLE. make and make
install completed without errors, although i did have to run sudo make
install, otherwise I got an error when it tried to copy oracle libs to the
qt system folder.
When starting the qgis app, I get:
./qgis: error while loading shared libraries: libqgis_core.so.2.3.0: cannot
open shared object file: No such file or directory
Any ideas of how to figure out what went wrong? I'm only doing the custom
build to enable oracle support-
Chris-
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140502/43cd9214/attachment.html>
