[Qgis-developer] error starting qgis (built from source)
chris marx
chrismarx at gmail.com
Fri May 2 13:53:36 PDT 2014
So those options already had the correct paths, so I didn't need to update
them. I have the oracle instant client and sdk libraries installed, and
cmake didn't complain about not finding them. Any other ideas?
On Fri, May 2, 2014 at 4:29 PM, Larry Shaffer <larrys at dakotacarto.com>wrote:
> Hi Chris,
> On Fri, May 2, 2014 at 1:47 PM, chris marx <chrismarx at gmail.com> wrote:
>> I followed the instructions here:
>> https://raw.githubusercontent.com/qgis/QGIS/master/INSTALL
>> and did the build on a clean ubuntu 12.04 64bit vm. the only thing i
>> changed from the vanilla build was to enable WITH_ORACLE. make and make
>> install completed without errors, although i did have to run sudo make
>> install, otherwise I got an error when it tried to copy oracle libs to the
>> qt system folder.
>> When starting the qgis app, I get:
>> ./qgis: error while loading shared libraries: libqgis_core.so.2.3.0:
>> cannot open shared object file: No such file or directory
>> Any ideas of how to figure out what went wrong? I'm only doing the custom
>> build to enable oracle support-
> The support still needs access to the Oracle Instant Client library
> 'libclntsh'.
> You can get binaries here:
> http://www.oracle.com/technetwork/database/features/instant-client/index-097480.html
> You'll need at least the Basic Lite and the SDK (for the headers).
> If you install to a non-standard location, you will probably also need to
> define:
> -D OCI_INCLUDE_DIR=<path-to-oracle-client-sdk>/sdk/include
> -D OCI_LIBRARY=<path-to>/lib/libclntsh.dylib
> Coincidentally, when searching for whether there are pre-built binaries as
> deb packages, I came across a similar answer, that I believe you provided,
> via Kyngchaos. :-)
> http://gis.stackexchange.com/a/75817/6725
> Regards,
> Larry
>> Chris-
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140502/634198cf/attachment.html>
