[Qgis-developer] QGIS on ubuntu 14.04
Albin Blaschka
albin.blaschka at standortsanalyse.net
Mon May 5 02:56:33 PDT 2014
Hello!
Am 05.05.2014 03:26, schrieb Randal Hale:
> debhttp://qgis.org/debian trusty main
> deb-srchttp://qgis.org/debian trusty main
> I'm getting an error on installation:
> /sudo apt-get install qgis python-qgis //
> //Reading package lists... Done//
> //Building dependency tree //
> //Reading state information... Done//
> //Some packages could not be installed. This may mean that you have//
> //requested an impossible situation or if you are using the unstable//
> //distribution that some required packages have not yet been created//
> //or been moved out of Incoming.//
> //The following information may help to resolve the situation://
> //The following packages have unmet dependencies://
> // python-qgis : Depends: python-spatialite but it is not installable//
> //E: Unable to correct problems, you have held broken packages/.
I can confirm - I have the same problem, on Kubuntu 14.04...
regards,
Albin
| Albin Blaschka, Mag.rer.nat.
| Etrichstrasse 26, A-5020 Salzburg
| * www.albinblaschka.info *
| * www.researchgate.net/profile/Albin_Blaschka *
| - It's hard to live in the mountains, hard but not hopeless!
