[Qgis-developer] error starting qgis (built from source)
chris marx
chrismarx at gmail.com
Mon May 5 10:21:44 PDT 2014
Yay! Ok, that did it. So, did I do something wrong? After running updatedb,
locate found the libraries in "/home/chrismarx/apps/lib/" . According to
the build instructions, it suggested to create :
mkdir -p ${HOME}/apps
and build the app into there. Is that where those libraries should have
ended up?
On Mon, May 5, 2014 at 12:50 PM, Yves Jacolin <yjacolin at free.fr> wrote:
> Le lundi 5 mai 2014, 10:26:34 chris marx a écrit :
> > Hi,
> > Ok, some of this is a bit unfamiliar for me, but here goes. So, I ran
> ldd
> > on the qgis app, and it very clearly shows that that libqgis_core was not
> > found:
> > chrismarx at ubuntu:~/apps/bin$ ldd ./qgis
> > linux-vdso.so.1 => (0x00007fff12158000)
> > libqwt-qt4.so.5 => /usr/lib/libqwt-qt4.so.5 (0x00007f7b3606f000)
> > libQtSql.so.4 => /usr/lib/x86_64-linux-gnu/libQtSql.so.4
> > (0x00007f7b35e30000)
> > libQtWebKit.so.4 => /usr/lib/x86_64-linux-gnu/libQtWebKit.so.4
> > (0x00007f7b34077000)
> > libgdal1.7.0.so.1 => /usr/lib/libgdal1.7.0.so.1 (0x00007f7b3366d000)
> > libqgis_core.so.2.3.0 => not found
> > libqgis_gui.so.2.3.0 => not found
> > libqgis_analysis.so.2.3.0 => not found
> This is the problem, if you added your correct lib path in
> /etc/ld.so.conf.d/qgis.conf (filename is not important, only the extension
> is
> important) then run sudo ldconfig your system should find them.
> First, run sudo updatedb then wait for a while. Finaly check the location
> with:
> locate libqgis_gui.so.2.3.0
> It gives you at least two location: your build src and your lib install
> path.
> Take the second one and put it into /etc/ ld.so.conf.d/qgis.conf, run again
> sudo ldconfig
> check again with your ldd command.
> Y.
> Yves Jacolin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140505/3897db6f/attachment.html>
