[Qgis-developer] Is there an advantage in using pyuic on command line instead of uic.loadUi in plugin source?
Tim Sutton
lists at linfiniti.com
Mon May 5 23:13:49 PDT 2014
Hi
On Mon, Apr 28, 2014 at 2:30 PM, Régis Haubourg <
regis.haubourg at eau-adour-garonne.fr> wrote:
> Hi Anita,
> I wasn't aware of that possibility.
> That would be great to document that in pyQgis Cookbook and to upgrade
> plugin builder.
Note that I have been overhauling the plugin builder on my fork [1]
(subject to review to see if others find my approach palatable). I will
implement Anita's suggestion there too.
[1] https://github.com/timlinux/Qgis-Plugin-Builder
Regards
Tim
> That compile part is over complicated for new users and
> probably we loose some potential contributors..
> Cheers
> Régis
> http://osgeo-org.1560.x6.nabble.com/Is-there-an-advantage-in-using-pyuic-on-command-line-instead-of-uic-loadUi-in-plugin-source-tp5137307p5137516.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140506/e0f7c898/attachment.html>
