[Qgis-developer] Problems editing WFS in QGIS
rldhont rldhont at gmail.com
Wed May 7 00:24:50 PDT 2014
Hi Scott,
The patch has been merged and backported to release 2.2
https://github.com/qgis/QGIS/pull/1266
https://github.com/qgis/QGIS/commit/a98df93a0db86db0b41431b44d0d5835c7c892a6#diff-32d7f8e430e38ae79be2ead93f97a418
https://github.com/qgis/QGIS/commit/ad21b90b613afd3beae0e4192d02883d0ca3ff99#diff-32d7f8e430e38ae79be2ead93f97a418
I hope a bugfix will be released.
Regards,
René-Luc
Le 06/05/2014 18:44, Scott Clark a écrit :
> Hello Rene´,
>   Did this fix get in as a patch?  If so, where can I get it for 2.2?
> Thanks!
> Scott
> Scott Clark wrote:
>> Excellent news and many thanks!
>> René-Luc D'Hont wrote:
>>> Hi Scott,
>>> I have discovered this issue next week and I'm working on a bugfix.
>>> I hope to propose a patch or a pull request tomorrow.
>>> I'd like to see this fix backported.
>>> Regards
>>> Le 24 mars 2014 14:58, "Scott Clark" <sctevl at gmail.com
>>> <mailto:sctevl at gmail.com>> a écrit :
>>>     Upon further investigation it appears that WFS authentication is
>>>     broken.  Further testing shows that the Add WFS dialog does not
>>>     display layers that require basic auth - even when the login is
>>>     supplied.  It will only show the public layers.  Note that the
>>>     WMS auth works great for me.
>>>     When you try to edit a WFS-T, I believe it is also failing to
>>>     use the supplied login info.  Which results in the error I'm
>>>     seeing below.
>>>     I've added the additional details to the existing bug at
>>>     http://hub.qgis.org/issues/9234
>>>     Since this makes WFS of very limited use, is this planned to be
>>>     fixed in an up-coming release?  I'll happily be a tester for this!
>>>     Scott
>>>     Scott Clark wrote:
>>>>     I've been having no success using the digitizing toolbar with
>>>>     WFS-T. I'm using QGIS 2.2.0 with a GeoServer 2.4. The layers
>>>>     are displaying fine when added through the Add WFS dialog, and
>>>>     the editing UI is functional.  However, on save, it fails
>>>>     (after freezing up QGIS for a minute or so) with the following
>>>>     message:
>>>>     Could not commit changes to layer geonode:incidentes_copeco
>>>>     Errors: ERROR: 1 feature(s) not added.
>>>>     Provider errors:
>>>>     unhandled response: html
>>>>     It's not specific to these layers and it fails on all of the
>>>>     layers I pick.  I've successfully tested editing using WFS-T on
>>>>     this particular server using both our OL3 and our mobile client.
>>>>       Any ideas on workarounds or what might be going wrong?
>>>>     Thanks,
>>>>      Scott
>>>     _______________________________________________
>>>     Qgis-developer mailing list
>>>     Qgis-developer at lists.osgeo.org
>>>     <mailto:Qgis-developer at lists.osgeo.org>
>>>     http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140507/1706038d/attachment.html>
