[Qgis-developer] GDAL 1.11 new formats
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Wed May 7 14:36:21 PDT 2014
Yes, though I have to admit that I have no experience with building GDAL with SOSI support on Mac, but I know that the underling OpenFYBA lib has been successfully build on Mac, so I assume the Unix build hints should apply for Mac also  for GDAL/OGR.
Probably I should note, that the free map data of the Norwegian Mapping Authority (http://data.kartverket.no/download/) also come in SOSI format (vector)...
Cheers
Stefan
-----Original Message-----
From: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Jeff McKenna
Sent: 7. mai 2014 22:56
To: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] GDAL 1.11 new formats
On 2014-05-07, 5:31 PM, Blumentrath, Stefan wrote:
> The Norwegian SOSI format (Vector) is also "new" - or more precise
> improved - in terms of build process in GDAL 1.11.
> On windows, it is now supported as a GDAL plugin and available in
> OSGeo4W. On Linux / Mac it still has to be built from source with an
> external library dependency (https://github.com/kartverket/fyba).
> SOSI is a bit peculiar, but it is the format of the official map data
> in Norway, used by public authorities.  The driver says it is
> Read/Write but writing is not fully implemented (yet).
> It would be splendid to be able to open SOSI files directly in QGIS
> (see also http://hub.qgis.org/issues/3708) and also write it once the
> public mapping authority fully implements the driver...
Hello Stefan,
That is very interesting.  Are all of your notes included on the GDAL Buildhints page, for Windows and Linux/Mac?
http://trac.osgeo.org/gdal/wiki/SOSI
-jeff
Jeff McKenna
MapServer Consulting and Training Services http://www.gatewaygeomatics.com/
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
