[Qgis-developer] Rendering a map in QgsComposition on Win 7 / 8
pgierski pgierski at o2.pl
Fri May 9 01:35:52 PDT 2014
I've tried to compare these project on which rendering works to these on which it doesn't.
They have the same tiff raster format, they have different raster layers number, but I've deleted excessive layers and in PDF I only have blank space instead of a map.
Also when rendering is not working, the output PDF has a lot smaller size and renders / opens instantly. I don't know in what format the image in PDF is stored, but it looks like it's just not rendered at all.
Any ideas?
Dnia 9 maja 2014 10:25 pgierski <pgierski at o2.pl> napisał(a):
> Thanks, I've added your line to the code.
> At the beggining nothing has changed, but I've opened a few different
> projects to test and for some (2) of them rendering the map worked, but for
> most of tested (5) not.
> I've also commented the line you've provided and nothing changes (still
> those 2 works, but majority not).
> On Linux still everything works.
> I guess maybe it's something with image caching?
> Cheers, Przemysław Gierski.
> Dnia 8 maja 2014 12:39 Nyall Dawson <nyall.dawson at gmail.com> napisał(a):
> > On 8 May 2014 20:23, pgierski <pgierski at o2.pl> wrote:
> > > composerMap = QgsComposerMap(c,
> > > 14.7026,113.85,map_width_on_print_mm,map_height_on_print_mm)
> > > composerMap.setFrameEnabled(True)
> > > composerMap.setFrameOutlineWidth(0.5)
> > > c.addItem(composerMap)
> > What if you try explicitly setting composerMap's extent here? ie,
> > composerMap.setNewExtent(rect)
> > Nyall
> Qgis-developer mailing list
