[Qgis-developer] Adding a script to Processing?
Victor Olaya
volayaf at gmail.com
Sun May 11 23:18:17 PDT 2014
I already had a look at those script. The idea is very good, but the
implementation is not ideal for an example.For instance, it uses message
dialogs, something that should't be used Instead, exceptions should be
raised and Processing will take care of that, and that will allow to use
the algoritm correctly in the modeler.
So the answer is yes, but I would like to polish the code before adding t
as an example that others might follow.
2014-05-12 7:57 GMT+02:00 Paolo Cavallini <cavallini at faunalia.it>:
> Hi.
> Should we add this to Processing?
> http://ssrebelious.wordpress.com/2014/01/04/unifying-extent-and-resolution-of-rasters-using-processing-framework-in-qgis
> All the best.
> Paolo Cavallini - www.faunalia.eu
> Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140512/27fbd672/attachment.html>
