[Qgis-developer] Licence of proprietary web services
Alessandro Pasotti
apasotti at gmail.com
Tue May 13 09:25:32 PDT 2014
2014-05-13 18:05 GMT+02:00 Paolo Cavallini <cavallini at faunalia.it>:
> Il 13/05/2014 18:03, Alessandro Pasotti ha scritto:
> > If is it user responsibility to enter webservices addresses and hit
> rate, then I
> > wouldn't care.
> In this case, a number of services are already included, so the user might
> not be aware.
> Thanks.
I guess this plugin might also break Google TOS:
http://plugins.qgis.org/plugins/go2streetview/
See:
https://developers.google.com/maps/terms
(g) *No Use of Content without a Google Map.* You must not use or display
the Content without a corresponding Google map, unless you are explicitly
permitted to do so in the Maps APIs Documentation, or through written
permission from Google. In any event, you must not use or display the
Content on or in conjunction with a non-Google map. For example, you must
not use geocodes obtained through the Service in conjunction with a
non-Google map. As another example, you must not display Street View
imagery alongside a non-Google map, but you may display Street View imagery
without a corresponding Google map because the Maps APIs Documentation
explicitly permits you to do so.
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140513/cc90721a/attachment.html>
