[Qgis-developer] Processing (Saga) help files
Paolo Cavallini
cavallini at faunalia.it
Thu May 15 05:07:49 PDT 2014
Il 07/05/2014 10:57, matteo ha scritto:
> thanks to the last update of Processing, help files for some Saga
> algorithms are available through the Help Tab.
> If you want to contribute writing some help, the procedure is very
> straightforward. You just need to go here
> https://github.com/qgis/QGIS/tree/master/python/plugins/processing/algs/saga/help
> choose the algorithm, click on `edit` and fill the fields.
> Once you have done, click on the green button `Propose file change`,
> and that's it.
Hi all.
FYI, a suggestion:
http://hub.qgis.org/issues/10275
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
