[Qgis-developer] GDAL 1.11 new formats
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Fri May 16 13:51:38 PDT 2014
Hi Larry,
I tried now with QGIS 2.3 nightly build (2.3.0-81) in OSGeo4W.
When I try to open a SOSI file in QGIS I still get the “Invalid Source” error message.
The gdal-sosi-plugin package in OSGeo4W is built against GDAL 1.10. Can that be a problem? Will I have to rebuild the plugin against GDAL 1.11 in order to make it accessible for QGIS (ogrinfo --format lists SOSI).
Or is the solution to install OSGeo4W from scratch?
Any other ideas?
Cheers
Stefan
From: larry at shafferinteractive.com [mailto:larry at shafferinteractive.com] On Behalf Of Larry Shaffer
Sent: 14. mai 2014 02:56
To: Stott, James
Cc: Blumentrath, Stefan; Jeff McKenna; qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] GDAL 1.11 new formats
On Thu, May 8, 2014 at 12:03 AM, Stott, James <fmrojst at fylkesmannen.no<mailto:fmrojst at fylkesmannen.no>> wrote:
I second Stefan's comments. Having direct SOSI support will really strengthen the position of QGIS here in Norway.
We do a lot of work with SOSI, and it would be great to open (and eventually edit) SOSI files directly rather than having to convert them first.
I added an extension filter for SOSI to QGIS master [0].
Also, for Mac, I added Homebrew formulae for the OpenFYBA lib (fyba) [1] and a GDAL/OGR shared plugin (gdal-sosi) [2]. The SOSI support was recently added to the base GDAL formula (gdal) [3], so recompiling it after installation of fyba will also work, e.g.:
$ brew tap osgeo/osgeo4mac
$ brew update
Then...
$ brew upgrade gdal <-- this will install 1.11.0 'bottle,' if not already done
$ brew install fyba
$ brew install gdal-sosi <-- installs ogr_SOSI.dylib plugin in HOMEBREW_PREFIX/lib/gdalplugins/
Or...
$ brew install fyba
$ brew reinstall gdal --build-from-source --enable-unsupported
QGIS built against GDAL/OGR 1.11 with the sample .sos file loaded [4].
Please submit any issues with fyba or gdal-sosi formulae to OSGeo4Mac tracker [5].
[0] https://github.com/qgis/QGIS/commit/9804d17
[1] https://github.com/OSGeo/homebrew-osgeo4mac/commit/c93a2cf
[2] https://github.com/OSGeo/homebrew-osgeo4mac/commit/0db85d8
[3] https://github.com/Homebrew/homebrew/blob/master/Library/Formula/gdal.rb#L187
[4] http://trac.osgeo.org/gdal/wiki/SOSI#TestingtheSOSIdriver ,
http://drive.dakotacarto.com/qgis/sosi.png
[5] https://github.com/OSGeo/homebrew-osgeo4mac/issues
Regards,
Larry
James
-----Opprinnelig melding-----
Fra: qgis-developer-bounces at lists.osgeo.org<mailto:qgis-developer-bounces at lists.osgeo.org> [mailto:qgis-developer-bounces at lists.osgeo.org<mailto:qgis-developer-bounces at lists.osgeo.org>] På vegne av Blumentrath, Stefan
Sendt: 7. mai 2014 23:36
Til: Jeff McKenna; qgis-developer at lists.osgeo.org<mailto:qgis-developer at lists.osgeo.org>
Emne: Re: [Qgis-developer] GDAL 1.11 new formats
Yes, though I have to admit that I have no experience with building GDAL with SOSI support on Mac, but I know that the underling OpenFYBA lib has been successfully build on Mac, so I assume the Unix build hints should apply for Mac also for GDAL/OGR.
Probably I should note, that the free map data of the Norwegian Mapping Authority (http://data.kartverket.no/download/) also come in SOSI format (vector)...
Cheers
Stefan
-----Original Message-----
From: qgis-developer-bounces at lists.osgeo.org<mailto:qgis-developer-bounces at lists.osgeo.org> [mailto:qgis-developer-bounces at lists.osgeo.org<mailto:qgis-developer-bounces at lists.osgeo.org>] On Behalf Of Jeff McKenna
Sent: 7. mai 2014 22:56
To: qgis-developer at lists.osgeo.org<mailto:qgis-developer at lists.osgeo.org>
On 2014-05-07, 5:31 PM, Blumentrath, Stefan wrote:
> The Norwegian SOSI format (Vector) is also "new" - or more precise
> improved - in terms of build process in GDAL 1.11.
> On windows, it is now supported as a GDAL plugin and available in
> OSGeo4W. On Linux / Mac it still has to be built from source with an
> external library dependency (https://github.com/kartverket/fyba).
> SOSI is a bit peculiar, but it is the format of the official map data
> in Norway, used by public authorities. The driver says it is
> Read/Write but writing is not fully implemented (yet).
> It would be splendid to be able to open SOSI files directly in QGIS
> (see also http://hub.qgis.org/issues/3708) and also write it once the
> public mapping authority fully implements the driver...
Hello Stefan,
That is very interesting. Are all of your notes included on the GDAL Buildhints page, for Windows and Linux/Mac?
-jeff
Jeff McKenna
MapServer Consulting and Training Services http://www.gatewaygeomatics.com/
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org<mailto:Qgis-developer at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140516/e3a1f83e/attachment-0001.html>
