[Qgis-developer] Geospackage Slow in QGIS
Andrea Peri aperi2007 at gmail.com
Sat May 17 01:04:35 PDT 2014
More probably there is some optimal adjust chance, but the geopackage
format is for exchange data. It is sub optimal for work daily.
 Il 17/mag/2014 09:40 "Jeremy Palmer" <JPalmer at linz.govt.nz> ha scritto:
> I've just been using the new implementation of Geopackage in QGIS :)
> However each map render or feature info is very slow for large database
> files - even with the new GDAL/OGR Geopackage spatial index support. Each
> time QGIS renders a new map view or executes a feature info it re-opens the
> Geopackage file in QgsOgrFeatureIterator via OGROpen, and the Geopackage
> driver open method runs PRAGMA integrity_check which is very slow (4 secs
> with my 2GB test file). This integrity check is actually a Geopackage
> requirement.
> How can this be fixed? At the in QGIS or GDAL/OGR level?
> Cheers,
> Jeremy
> This message contains information, which may be in confidence and may be
> subject to legal privilege. If you are not the intended recipient, you must
> not peruse, use, disseminate, distribute or copy this message. If you have
> received this message in error, please notify us immediately (Phone 0800
> 665 463 or info at linz.govt.nz) and destroy the original message. LINZ
> accepts no responsibility for changes to this email, or for any
> attachments, after its transmission from LINZ. Thank You.
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140517/78493a64/attachment.html>
