[Qgis-developer] Geospackage Slow in QGIS
Jeremy Palmer JPalmer at linz.govt.nz
Sat May 17 13:14:54 PDT 2014
Hi Even,
Thanks for the change! I've now tested the GDAL trunk with QGIS and it's lightning fast with large files - problem solved.
Thanks once again,
Jeremy
________________________________________
From: Even Rouault [even.rouault at mines-paris.org]
Sent: Saturday, 17 May 2014 10:48 p.m.
To: qgis-developer at lists.osgeo.org
Cc: Stefan Keller; Jeremy Palmer
Subject: Re: [Qgis-developer] Geospackage Slow in QGIS
Le samedi 17 mai 2014 10:46:39, Stefan Keller a écrit :
> So it's this code fragment?
> 419     /* Requirement 6: The SQLite PRAGMA integrity_check SQL command
> SHALL return â??okâ? */
> 420    /* http://opengis.github.io/geopackage/#_file_integrity */
> 421    if( strncmp(pszFilename, "/vsicurl/", strlen("/vsicurl/")) != 0 &&
> 422        OGRERR_NONE != PragmaCheck("integrity_check", "ok", 1) )
> Looks strange to me why a single file check woold be the bottlenet since
> this should be a single call.
> I would have expected that some repeated calls (like reading
> objects/records and checking SRID or data types) would be the bottleneck
> since SQlite is not performant when used with PRAGMA checks. This would be
> a check one could disable with a parameter.
I've just noticed that thread. Actually I found that integrity_check was slow
when operating on remote databases with /vsicurl/ and didn't verify how slow
it could be with local big files, but its documentation at
http://www.sqlite.org/pragma.html#pragma_integrity_check suggests that it
might be bery slow indeed.
Reading the GeoPackage spec, nothing mandates to do the integrity_check at
open time. It only mandates that if you run "pragma integrity_check" it should
retrun OK. So I've disabled the check by default.
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
