[Qgis-developer] Geospackage Slow in QGIS
Jeremy Palmer
JPalmer at linz.govt.nz
Sat May 17 13:19:00 PDT 2014
I'm wondered why QGIS needs a native SpatiaLite provider and connection dialogue any more. Unlike other database providers such as PostGIS, Oracle, MSSQL the SpatiaLite provider doesn't seem to have anything special that requires a QGIS provider. From a users perspective it just adds to the confusion and complexity for adding data. Why not just use GDAL/OGR for both Geopackage and Spatialite?
Cheers
Jeremy
________________________________________
Sent: Sunday, 18 May 2014 12:24 a.m.
To: Martin Dobias
Cc: Jeremy Palmer; qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] Geospackage Slow in QGIS
Hi Martin
It has a different binary encoding compared to Spatialite.
And in addition it integrates raster tiles (MBTiles) and metadata.
-S.
2014-05-17 14:10 GMT+02:00 Martin Dobias <wonder.sk at gmail.com<mailto:wonder.sk at gmail.com>>:
Hi
On Sat, May 17, 2014 at 2:32 PM, Jeremy Palmer <JPalmer at linz.govt.nz<mailto:JPalmer at linz.govt.nz>> wrote:
> I've just been using the new implementation of Geopackage in QGIS :) However each map render or feature info is very slow for large database files - even with the new GDAL/OGR Geopackage spatial index support. Each time QGIS renders a new map view or executes a feature info it re-opens the Geopackage file in QgsOgrFeatureIterator via OGROpen, and the Geopackage driver open method runs PRAGMA integrity_check which is very slow (4 secs with my 2GB test file). This integrity check is actually a Geopackage requirement.
> How can this be fixed? At the in QGIS or GDAL/OGR level?
Actually I am wondering how different is the format of GeoPackage from
the format of SpatiaLite... we could use our native SpatiaLite
provider also for GeoPackage files if they are close enough. Any
ideas?
Regards
Martin
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org<mailto:Qgis-developer at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-developer
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
