[Qgis-developer] Revival of "OGR Layer Converter" plugin?
Giovanni Manghi
giovanni.manghi at faunalia.pt
Sun May 18 07:11:02 PDT 2014
> Four years ago you submitted the "OGR Layer Converter" plugin to QGIS trunk
> (http://hub.qgis.org/issues/1249 ). Since then OGR became part of the usual
> "Open Vector Layer..." dialog.
> But this "open..." dialog includes no parameter ogr2ogr would have -
> neither source nor target creation layer options.
> What do you think of a revival of the plugin which would give control to an
> advanced user over those options?
in the processing toolbox there is a tool (ogr converter) that does
exactly the same, and allows you to add specific parameters.
I submiited a PR today to fix issues with output formats strings
https://github.com/qgis/QGIS/pull/1365
cheers
-- G --
