[Qgis-developer] Error installing nightly debs
Paolo Cavallini cavallini at faunalia.it
Sun May 18 23:16:00 PDT 2014
Hi all.
Installing qgis-nightly from
deb     http://qgis.org/debian-nightly sid main
results in an error:
aptitude install python-qgis
The following NEW packages will be installed:
  python-qgis
0 packages upgraded, 1 newly installed, 0 to remove and 1 not upgraded.
Need to get 0 B/2778 kB of archives. After unpacking 14.1 MB will be used.
Retrieving bug reports... Done
Parsing Found/Fixed information... Done
(Reading database ... 391061 files and directories currently installed.)
Preparing to unpack .../python-qgis_2.3.0+git20140518+0f3158a~unstable1_amd64.deb ...
Unpacking python-qgis (2.3.0+git20140518+0f3158a~unstable1) ...
dpkg: error processing archive
/var/cache/apt/archives/python-qgis_2.3.0+git20140518+0f3158a~unstable1_amd64.deb
(--unpack):
 trying to overwrite '/usr/lib/libqgispython.so.2.3.0', which is also in package
libqgispython2.3.0 2.3.0+git20140518+0f3158a~unstable1
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
All the best.
Paolo Cavallini - www.faunalia.eu
Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
