[Qgis-developer] Use Georeferencer Core-Plugin with python
    G. Allegri
    giohappy at gmail.com
    Mon May 19 07:33:04 PDT 2014
It depends on what parts of the Georeferencer you need. If you don't need
the GUI but only the math, you could consider writing a SIP wrapper
around QgsGeorefTransformInterface implementations [1].
Otherwise, if Python performance would suffice, you could grab the low
level math from QgsGeorefTransform and QgsLeastSquares [2] and translate it
to Python.
giovanni
[1]
https://github.com/qgis/QGIS/blob/master/src/plugins/georeferencer/qgsgeoreftransform.cpp
[2]
https://github.com/qgis/QGIS/blob/master/src/plugins/georeferencer/qgsleastsquares.cpp
2014-05-19 16:32 GMT+02:00 G. Allegri <giohappy at gmail.com>:
> to Python.
> giovanni
> [1]
> [2]
> 2014-05-19 16:10 GMT+02:00 Felix Schmidt <felix.schmidt at uni-weimar.de>:
> Hello Giovanni,
>> thanks for your answer. Do you think it is easier to write the Plugin for
>> the historical border extraction in c++ instead of python, cause of the
>> binding implementation?
>> Felix
>> Am 19.05.2014 14:52, schrieb G. Allegri:
>>> Hi Felix,
>>> I fear you will have to write your own bindings if you want to leavarage
>>> the Georeferencer plugin code. It's a plugin, so it's functionality isn't
>>> exposed through QGIS API.
> Giovanni Allegri
> http://about.me/giovanniallegri
> Twitter: https://twitter.com/_giohappy_
> blog: http://blog.spaziogis.it
> GEO+ geomatica in Italia http://bit.ly/GEOplus
Giovanni Allegri
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140519/460a2493/attachment.html>
