[Qgis-developer] Use Georeferencer Core-Plugin with python
Felix Schmidt
felix.schmidt at uni-weimar.de
Mon May 19 08:34:41 PDT 2014
@Matthias: what do you mean with:
Am 19.05.2014 16:41, schrieb Matthias Kuhn: "the code is not exported to
the gui or core libraries/sip modules"?
> It will not be so easy to just write wrappers because the code is not
> exported to the gui or core libraries/sip modules.
> I have written code that makes it possible to generate python bindings
> for (C++) plugins and I'm considering creating a pull-request for it.
> Matthias
> On 05/19/2014 04:33 PM, G. Allegri wrote:
>> It depends on what parts of the Georeferencer you need. If you don't
>> need the GUI but only the math, you could consider writing a SIP
>> wrapper around QgsGeorefTransformInterface implementations [1].
>> Otherwise, if Python performance would suffice, you could grab the
>> low level math from QgsGeorefTransform and QgsLeastSquares [2] and
>> translate it to Python.
>> giovanni
>> [1]
>> https://github.com/qgis/QGIS/blob/master/src/plugins/georeferencer/qgsgeoreftransform.cpp
>> [2]
>> https://github.com/qgis/QGIS/blob/master/src/plugins/georeferencer/qgsleastsquares.cpp
>> 2014-05-19 16:32 GMT+02:00 G. Allegri <giohappy at gmail.com
>> <mailto:giohappy at gmail.com>>:
>> don't need the GUI but only the math, you could consider writing
>> a SIP wrapper around QgsGeorefTransformInterface implementations
>> [1].
>> the low level math from QgsGeorefTransform and QgsLeastSquares
>> [2] and translate it to Python.
>> giovanni
>> [1]
>> [2]
>> 2014-05-19 16:10 GMT+02:00 Felix Schmidt
>> <felix.schmidt at uni-weimar.de <mailto:felix.schmidt at uni-weimar.de>>:
>> Hello Giovanni,
>> thanks for your answer. Do you think it is easier to write
>> the Plugin for the historical border extraction in c++
>> instead of python, cause of the binding implementation?
>> Felix
>> Am 19.05.2014 14:52, schrieb G. Allegri:
>> Hi Felix,
>> I fear you will have to write your own bindings if you
>> want to leavarage the Georeferencer plugin code. It's a
>> plugin, so it's functionality isn't exposed through QGIS API.
>> Giovanni Allegri
>> http://about.me/giovanniallegri
>> Twitter: https://twitter.com/_giohappy_
>> blog: http://blog.spaziogis.it
>> GEO+ geomatica in Italia http://bit.ly/GEOplus
>> Giovanni Allegri
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140519/7426343c/attachment-0001.html>
