[Qgis-developer] python: no module name core
Alexander Bruy alexander.bruy at gmail.com
Tue May 20 10:45:32 PDT 2014
Hi Richard,
Thanks for reply, I already found this by myself and started to write email to
list, when got your detailed answer. Thanks anyway, maybe this instructions
will be useful for others too.
2014-05-20 20:38 GMT+03:00 Richard Duivenvoorde <rdmailings at duif.net>:
> Hi Alexander,
> that is another problem, discussed yesterday.
> You have a build which installed soem customwidgets stuff for qgis
> widgets to be used in Qt-Designer
> The option:
> -DWITH_CUSTOM_WIDGETS=FALSE
> would have prevented that, but was enabled by default.
> Since today it is false again by default I think...
> The problem is that by the global install you have a
> qgis_customwidgets.py somewhere in
> /usr/lib/python2.7/dist-packages/PyQt4.
> and a libqgis_customwidgets.so.2.3.0 file somehere around
> /usr/lib/qt4/plugins/designer/
> both should be removed if you do not have the qgis libs installed globally.
> All this is solved now, but I think you should remove those to be clean
> again.
> Regards,
> Richard
> On 20-05-14 18:21, Alexander Bruy wrote:
>> Hi,
>> I also have troubles with Python plugins and bindings. For example build failed
>> with error
>> [  6%] Generating ui_frmVectorGrid.py
>> An unexpected error occurred.
>> Check that you are using the latest version of PyQt and send an error report to
>> support at riverbankcomputing.com, including the following information:
>>   * your version of PyQt (4.9.1)
>>   * the UI file that caused this error
>>   * the debug output of pyuic4 (use the -d flag when calling pyuic4)
>> make[2]: *** [python/plugins/fTools/tools/ui_frmVectorGrid.py] Error 1
>> make[2]: *** Waiting for unfinished jobs....
>> make[2]: *** [python/plugins/fTools/tools/ui_frmRandom.py] Error 1
>> make[1]: *** [python/plugins/fTools/tools/CMakeFiles/fTools-tools-stageinstall.dir/all]
>> Error 2
>> make[1]: *** Waiting for unfinished jobs....
>> This is strange, as my system has Qt 4.8.2 not 4.9.1 Cleant rebuild
>> and install doesn't
>> helps.
>> 2014-05-20 17:42 GMT+03:00 Nathan Woodrow <madmanwoo at gmail.com>:
>>> This seems to be due to my changes today, although I'm not sure what is
>>> going on unless I stuffed up the cmake files.
>>> qgis.core is now a package i.e folder and it imports the sip modules, now
>>> called _core, _gui, etc.
>>> For some reason the package is missing the core, gui, package folders.
>>> - Nathan
>>> On Wed, May 21, 2014 at 12:34 AM, Victor Olaya <volayaf at gmail.com> wrote:
>>>> it works fine here
>>>> It might be that you have a plugin that has a package called qgis, which
>>>> might be shadowing the core one.
>>>> 2014-05-20 16:27 GMT+02:00 Denis Rouzaud <denis.rouzaud at gmail.com>:
>>>>> Hi all,
>>>>> From python console, running from qgis.core import * gives:
>>>>> Traceback (most recent call last):
>>>>>   File "<stdin>", line 1, in <module>
>>>>>   File "/usr/lib/python2.7/dist-packages/qgis/__init__.py", line 36, in
>>>>> <module>
>>>>>     from qgis.core import QgsFeature, QgsGeometry
>>>>> ImportError: No module named core
>>>>> Any idea what's going on?
>>>>> Cheers,
>>>>> Denis
>>>>> _______________________________________________
>>>>> Qgis-developer mailing list
>>>>> Qgis-developer at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexander Bruy
