[Qgis-developer] qgis freezes when opening attribute table of a postgis layer without key value
Régis Haubourg regis.haubourg at eau-adour-garonne.fr
Wed May 21 02:53:27 PDT 2014
I'm facing a severe bug in qgis 2.2 and master here.
I have layers defined in existing project that do not have a key in
datasource definition.
It seems that when a table has a oid field, postgis connection dialog does
not ask for a key field (it is a multi column primary key in that case).
When i had manually in definition string key=oid,  all seems fine.
The major problem is that most user existing project will be impacted.
Did I miss something? Why is key=oid no more explicitly written in
datasource def?
Thanks for your lights
Régis
View this message in context: http://osgeo-org.1560.x6.nabble.com/qgis-freezes-when-opening-attribute-table-of-a-postgis-layer-without-key-value-tp5141587.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
