[Qgis-developer] qgis freezes when opening attribute table of a postgis layer without key value
Andrea Peri
aperi2007 at gmail.com
Wed May 21 04:28:08 PDT 2014
AFAIK the last postgres versione dismiss by default the oid.
Il 21/mag/2014 11:54 "Régis Haubourg" <regis.haubourg at eau-adour-garonne.fr>
ha scritto:
> Hi,
> I'm facing a severe bug in qgis 2.2 and master here.
> I have layers defined in existing project that do not have a key in
> datasource definition.
> It seems that when a table has a oid field, postgis connection dialog does
> not ask for a key field (it is a multi column primary key in that case).
> When i had manually in definition string key=oid, all seems fine.
> The major problem is that most user existing project will be impacted.
> Did I miss something? Why is key=oid no more explicitly written in
> datasource def?
> Thanks for your lights
> Régis
> http://osgeo-org.1560.x6.nabble.com/qgis-freezes-when-opening-attribute-table-of-a-postgis-layer-without-key-value-tp5141587.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140521/b79078e5/attachment.html>
