[Qgis-developer] Old styles not shown?
Paolo Cavallini
cavallini at faunalia.it
Thu May 22 05:27:12 PDT 2014
Il 22/05/2014 14:03, Martin Dobias ha scritto:
> Hi
> On Thu, May 22, 2014 at 6:30 PM, Andreas Neumann <a.neumann at carto.net> wrote:
>> Hi,
>> Can't we just say that old styling and old labeling does not work anymore?
> Seems to work for me. Tested with points/lines/polys shapefiles in
> QGIS source: tests/testdata. Those shapefiles come with .qml files
> which still use old symbology. Similar warning is emitted, just the
> saved version is 1.9.90.
Hi all.
Thanks for loking into this. Trying it again, some of the layers are now displayed.
Some are not, and switching them off results in a crash (probably unrelated).
Symbols are new, not old symbology.
Data and styles available if useful.
All the best
QGIS died on signal 11
warning: Could not load shared library symbols for linux-vdso.so.1.
Do you need "set solib-search-path" or "set sysroot"?
[New LWP 5679]
[New LWP 5678]
[New LWP 5677]
[New LWP 5666]
[New LWP 5665]
[New LWP 5664]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
warning: no loadable sections found in added symbol-file system-supplied DSO at
0x7fffe47fd000
0x00007f0242697ed9 in __libc_waitpid (pid=5682, stat_loc=0x7fffe47dc27c, options=0)
at ../sysdeps/unix/sysv/linux/waitpid.c:40
40 ../sysdeps/unix/sysv/linux/waitpid.c: File o directory non esistente.
[Current thread is 1 (Thread 0x7f0249fec7c0 (LWP 5663))]
#0 0x00007f0242697ed9 in __libc_waitpid (pid=5682, stat_loc=0x7fffe47dc27c,
options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:40
resultvar = 140737026836768
oldtype = 0
#1 0x00000000004f78d7 in qgisCrash(int) ()
No symbol table info available.
#2 <signal handler called>
No locals.
#3 0x00007f0244b344b1 in QAction::data() const () from
/usr/lib/x86_64-linux-gnu/libQtGui.so.4
#4 0x00007f02463f5d21 in QgsLayerTreeViewDefaultActions::zoomToLayer() () from
/usr/lib/libqgis_gui.so.2.3.0
#5 0x00000000007f29e1 in ?? ()
#6 0x00007f02457ae6aa in QMetaObject::activate(QObject*, QMetaObject const*, int,
void**) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#7 0x00007f0244b34572 in QAction::triggered(bool) () from
#8 0x00007f0244b35f43 in QAction::activate(QAction::ActionEvent) () from
#9 0x00007f0244ee9f82 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#10 0x00007f0244eea0ac in QAbstractButton::mouseReleaseEvent(QMouseEvent*) () from
#11 0x00007f0244fa0f9a in QToolButton::mouseReleaseEvent(QMouseEvent*) () from
#12 0x00007f0244b89cca in QWidget::event(QEvent*) () from
#13 0x00007f0244b3a6cc in QApplicationPrivate::notify_helper(QObject*, QEvent*) ()
#14 0x00007f0244b40e3a in QApplication::notify(QObject*, QEvent*) () from
#15 0x00007f0246a74e1b in QgsApplication::notify(QObject*, QEvent*) () from
/usr/lib/libqgis_core.so.2.3.0
#16 0x00007f024579a41d in QCoreApplication::notifyInternal(QObject*, QEvent*) () from
#17 0x00007f0244b40633 in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*,
QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) () from
#18 0x00007f0244bb233b in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#19 0x00007f0244bb0dac in QApplication::x11ProcessEvent(_XEvent*) () from
#20 0x00007f0244bd8712 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#21 0x00007f0240f0be04 in g_main_context_dispatch () from
/lib/x86_64-linux-gnu/libglib-2.0.so.0
#22 0x00007f0240f0c048 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#23 0x00007f0240f0c0ec in g_main_context_iteration () from
#24 0x00007f02457c7655 in
QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from
#25 0x00007f0244bd87c6 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#26 0x00007f0245798fef in
QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from
#27 0x00007f02457992e5 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) ()
#28 0x00007f024579eab9 in QCoreApplication::exec() () from
#29 0x00000000004f25ab in main ()
gdb returned 0
Paolo Cavallini - www.faunalia.eu
Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
