[Qgis-developer] Unable to add new features
Denis Rouzaud denis.rouzaud at gmail.com
Fri May 23 07:00:20 PDT 2014
Yes, I confirm for last master, at least on shapes and sqlite.
This is strange, I tested just after Matthias' merge and did not had any
trouble.
Can't tell which commit brought the trouble though.
On 23.05.2014 15:35, Ziegler Stefan wrote:
> It happens with a newly created shapefile.
> Regards
> Stefan
>> -----Ursprüngliche Nachricht-----
>> Von: Denis Rouzaud [mailto:denis.rouzaud at gmail.com]
>> Gesendet: Freitag, 23. Mai 2014 15:12
>> An: Ziegler Stefan; qgis-developer at lists.osgeo.org
>> Betreff: Re: [Qgis-developer] Unable to add new features
>> You might want to check the configuration of the fields in the layer properties and
>> report which field causes the problem.
>> There is a new widget API and there might be some problem with the translation from
>> old to new widgets.
>> On 23.05.2014 14:24, Ziegler Stefan wrote:
>>> Hi
>>> On current master (Ubuntu 12.04) I'm unable to add a new feature to existing layers
>> (shape, postgis). I can digitize the geometry and the form pops up but I cannot enter
>> values into the form and the ok button is greyed out.
>>> Can anyone confirm this or do I  have to change some magic new setting?
>>> Regards
>>> Stefan
>>> Freundliche Grüsse
>>> Stefan Ziegler
>>> Kantonsgeometer
>>> Amt für Geoinformation
>>> Amtliche Vermessung
>>> Rötistrasse 4
>>> 4500 Solothurn
>>> Telefon +41 32 627 75 96
>>> Telefax +41 32 627 75 98
>>> stefan.ziegler at bd.so.ch
>>> http://www.so.ch
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
