[Qgis-developer] Proposal for new features selection functionalities in Digitizing Tool Bar
Frédéric Jacon
frederic.jacon at camptocamp.com
Fri May 23 08:19:49 PDT 2014
Dear all,
We would like to have your feedbacks on our proposition to add new
selection functionnalities in the Digitizing Tool Bar.
These functions come from the 'SELECTPLUSFR' extensions, developed by
Christophe
MASSE (french Ministry of Ecology) and available here :
http://plugins.qgis.org/plugins/selectplus/
Originally 'SELECTPLUS' is a collection of tools for selecting objects on
vectors historically developed by Barry Rowlingson and supplemented by
Carson JQ Farmer.
SELECTPLUSFR includes a “Create Drawn Objects” tool that allows user to
create circles or rectangles.
Our proposal is to add the “Create Drawn Objects” tool into the
“digitizing” tool bar.
The procedure is as follows :
*Click* button to initialize the command ;
*Click in the map window* to place the center of the circle and get the
box set the properties of the circle (object proposed default).
The it is possible to :
change the type object ;
previewing dynamic drawing of the object ;
move the object by changing the X and Y coordinates (or scroll button) ;
change the attributes of the object : a circle radius or width and
height for a rectangle (or scroll button) ;
change the label associated with the object ;
change associated with the object position (*only for rectangles*) ;
switch to the current way (map window) or general control ;
recall the X and Y coordinates of the last point raised in the map
window ;
change the selection option on the layer to achieve (interaction with
toolbar) ;
make a selection with the object (no need to create it) ;
create object (memory layer).
If this proposal gets your attention and interest, we could be able to work
on it for the version after 2.4.
All feedbacks welcome !
Thanks !
Frédéric Jacon
Responsable d'agence - Chef de projets
Camptocamp France
Savoie Technolac
BP 352
48 avenue du Lac du Bourget
73372 Le Bourget du Lac, Cedex
www.camptocamp.com
+33 614 71 28 24 (mobile)
+33 479 26 57 97 (direct France)
+41 21 619 10 44 (direct Suisse)
+33 479 44 44 94 (standard)
+33 479 70 15 81 (fax)
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140523/53122504/attachment-0001.html>
