[Qgis-developer] Not working mac nightly
Larry Shaffer larrys at dakotacarto.com
Sat May 24 09:38:52 PDT 2014
Hi Vincent,
Thank you for reporting.
I have verified the issue here and it appears to be only with the 10.7
nightly's build script and .app bundling (issue not present for 10.6
nightly). I believe I know what the problem is, but will not be able to
physically access that Mac until sometime today, as it shuts down after
building the nightly on weekends - so no remote access right now.
Unfortunately, there is no quick fix to apply to the nightly you have
already downloaded.
When I get a chance to fix it, I'll force another nightly build, since
today's was not successful (may be unrelated).
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
On Sat, May 24, 2014 at 6:10 AM, Vincent TINET <v.tinet at agam.org> wrote:
> I tried to test the nightly builds a few days in a row and it doesn’t
> starts with the following error :
> Process:         QGIS_2.3-dev [3186]
> Path:
>  /Volumes/VOLUME/QGIS_2.3-dev.app/Contents/MacOS/QGIS_2.3-dev
> Identifier:      org.qgis.qgis-dev
> Version:         ???
> Code Type:       X86-64 (Native)
> Parent Process:  launchd [137]
> Responsible:     QGIS_2.3-dev [3186]
> User ID:         501
> Date/Time:       2014-05-24 14:08:16.406 +0200
> OS Version:      Mac OS X 10.9.3 (13D65)
> Report Version:  11
> Anonymous UUID:  898BFD97-214E-074A-83DA-999963349E20
> Sleep/Wake UUID: 074ECD49-01FF-408E-8E93-087F7A4E4776
> Crashed Thread:  0
> Exception Type:  EXC_BREAKPOINT (SIGTRAP)
> Exception Codes: 0x0000000000000002, 0x0000000000000000
> Application Specific Information:
> dyld: launch, loading dependent libraries
> Dyld Error Message:
>   Library not loaded: QtSvg.framework/Versions/4/QtSvg
>   Referenced from:
> /Volumes/VOLUME/QGIS_2.3-dev.app/Contents/MacOS/lib/libqwt.dylib
>   Reason: image not found
> Binary Images:
>     0x7fff6c4d4000 -     0x7fff6c507817  dyld (239.4)
> <042C4CED-6FB2-3B1C-948B-CAF2EE3B9F7A> /usr/lib/dyld
>     0x7fff89306000 -     0x7fff89306fff  com.apple.ApplicationServices (48
> - 48) <3E3F01A8-314D-378F-835E-9CC4F8820031>
> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
>     0x7fff8caa3000 -     0x7fff8caf1ff9  libstdc++.6.dylib (60)
> <0241E6A4-1368-33BE-950B-D0A175C41F54> /usr/lib/libstdc++.6.dylib
>     0x7fff8d29c000 -     0x7fff8d481fff  com.apple.CoreFoundation (6.9 -
> 855.16) <A63E680E-E4B2-368B-8564-9DBE0D8DDB91>
> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
>     0x7fff8e6e6000 -     0x7fff8e752fff  com.apple.framework.IOKit (2.0.1
> - 907.100.13) <057FDBA3-56D6-3903-8C0B-849214BF1985>
> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
>     0x7fff92c58000 -     0x7fff92c59ff7  libSystem.B.dylib (1197.1.1)
> <E303F2F8-A8CF-3DF3-84B3-F2D0EE41CCF6> /usr/lib/libSystem.B.dylib
>     0x7fff930a5000 -     0x7fff930a5fff  com.apple.CoreServices (59 - 59)
> <7A697B5E-F179-30DF-93F2-8B503CEEEFD5>
> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
>     0x7fff93268000 -     0x7fff93280fff  libexpat.1.dylib (12)
> <97F4A9A7-CB3E-3BBF-9314-4997FC770E52> /usr/lib/libexpat.1.dylib
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140524/aa3a72dd/attachment-0001.html>
