[Qgis-developer] Not working mac nightly
Vincent TINET
v.tinet at agam.org
Sun May 25 01:07:02 PDT 2014
It is loading fine with Larry’s new version.
Except that the psycopg2 python library is missing from the bundle. Processing (at least) is needing it to load.
Le 24 mai 2014 à 14:10, Vincent TINET <v.tinet at agam.org> a écrit :
> I tried to test the nightly builds a few days in a row and it doesn’t starts with the following error :
> Process: QGIS_2.3-dev [3186]
> Path: /Volumes/VOLUME/QGIS_2.3-dev.app/Contents/MacOS/QGIS_2.3-dev
> Identifier: org.qgis.qgis-dev
> Version: ???
> Code Type: X86-64 (Native)
> Parent Process: launchd [137]
> Responsible: QGIS_2.3-dev [3186]
> User ID: 501
> Date/Time: 2014-05-24 14:08:16.406 +0200
> OS Version: Mac OS X 10.9.3 (13D65)
> Report Version: 11
> Anonymous UUID: 898BFD97-214E-074A-83DA-999963349E20
> Sleep/Wake UUID: 074ECD49-01FF-408E-8E93-087F7A4E4776
> Crashed Thread: 0
> Exception Type: EXC_BREAKPOINT (SIGTRAP)
> Exception Codes: 0x0000000000000002, 0x0000000000000000
> Application Specific Information:
> dyld: launch, loading dependent libraries
> Dyld Error Message:
> Library not loaded: QtSvg.framework/Versions/4/QtSvg
> Referenced from: /Volumes/VOLUME/QGIS_2.3-dev.app/Contents/MacOS/lib/libqwt.dylib
> Reason: image not found
> Binary Images:
> 0x7fff6c4d4000 - 0x7fff6c507817 dyld (239.4) <042C4CED-6FB2-3B1C-948B-CAF2EE3B9F7A> /usr/lib/dyld
> 0x7fff89306000 - 0x7fff89306fff com.apple.ApplicationServices (48 - 48) <3E3F01A8-314D-378F-835E-9CC4F8820031> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
> 0x7fff8caa3000 - 0x7fff8caf1ff9 libstdc++.6.dylib (60) <0241E6A4-1368-33BE-950B-D0A175C41F54> /usr/lib/libstdc++.6.dylib
> 0x7fff8d29c000 - 0x7fff8d481fff com.apple.CoreFoundation (6.9 - 855.16) <A63E680E-E4B2-368B-8564-9DBE0D8DDB91> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
> 0x7fff8e6e6000 - 0x7fff8e752fff com.apple.framework.IOKit (2.0.1 - 907.100.13) <057FDBA3-56D6-3903-8C0B-849214BF1985> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
> 0x7fff92c58000 - 0x7fff92c59ff7 libSystem.B.dylib (1197.1.1) <E303F2F8-A8CF-3DF3-84B3-F2D0EE41CCF6> /usr/lib/libSystem.B.dylib
> 0x7fff930a5000 - 0x7fff930a5fff com.apple.CoreServices (59 - 59) <7A697B5E-F179-30DF-93F2-8B503CEEEFD5> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
> 0x7fff93268000 - 0x7fff93280fff libexpat.1.dylib (12) <97F4A9A7-CB3E-3BBF-9314-4997FC770E52> /usr/lib/libexpat.1.dylib
